have control on MAX and very little air - No Air coming out of vents
Discussion in 'Volvo Forum' started by JerryD13, Aug 23, 2017.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    VOLVO VNL D13
    ... I have the control knob on MAX -- and there is very little air coming out of my vents ?
    there are many things that it could be like the in cab Blower motor ???
    any ideas on what this could be?
    the air WORKS but is barley blowing air - it got progressively worse.
    Thanks in advance.
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    Sounds like the blower motor. But what truck do you have on my video love it did the same thing but was the controller that was bad
    JerryD13 Thanks this.
  4. JerryD13
    169
    126
    Oct 17, 2016
    Thanks for that -- dealer said the same thing - the controller was bad - will have to tear
    this apart to get to the controller.
  5. Sharky88
    715
    851
    Sep 25, 2013
    Not that hard just need to be careful when removing the trim tabs. Then it's just screws. On mine have to remove the radio and switches to get to the the screws for the controller. About a 10 minute job
  6. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    Have you checked the cabin air filter?
    JerryD13 and austinmike Thank this.
  7. sirjeff
    sirjeff Medium Load Member
    431
    1,226
    Dec 1, 2013
    Kootenays, British Columbia
    My truck is doing the same thing...... I was going to guess the blend door motor?? I'd rather it be the controller!
  8. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    check when the last time you changed you rcab filter was it's probably stuffed up maybe even blower motor but you should be able to hear if motor is working or not
  9. austinmike
    87,525
    My Freightliner did that recently. Stopped blowing in a matter of 10 min. Replaced that and works fine. Vovo may be different
  10. JerryD13
    169
    126
    Oct 17, 2016
    UOTE="Midnightrider909, post: 6355070, member: 188970"]Have you checked the cabin air filter?[/QUOTE]
    Yes Thanks
  11. JerryD13
    169
    126
    Oct 17, 2016
    ** Yes Sir -- and they were very dirty - I have changed both filters - the cabin and the sleeper FILTER 12.00 each at dealer -- but the problem was still there -- Thank You!!
    I need to go back to the truck and listen for the Blower Motor - THANKS
