Have no idea where to start!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by red211, Mar 5, 2011.
  1. red211
    red211 Bobtail Member
    33
    tn
    On the way home Thursday night I smelled coolant, pulled over and checked, recovery tank was cracked and blowing coolant out. The cooling fan has been on for a month or so, haven't had time to check if it's the switch like last time. Lower hose was cool, heater hot, so I took ti on the the barn, maybe 5 miles. When I got there it was still blowing coolant. I thought the thermostats were stuck so Fri I got new ones after finishing a job that was pressing. Today I pulled it in the barn to fix, in the time it took to build air and pull in, the tank was blowing coolant and lots of foam in tank. No oil, just foam that goes away after shutting off and sitting. I thought head gskt, but read on here where an air compressor can cause this. Back in Jan the air line froze, and blew the main line that comes off the compressor. After a new line and some alcohol all was good. The question is, what breaks inside the compressor and which line do I pressurize to check? I am hoping it is in the compressor instead of the engine. Good news will be welcome!!!
  3. crazy_mike
    crazy_mike Bobtail Member
    5
    piketon,oh
    I would check the water pump too.
  4. ranga
    ranga Bobtail Member
    16
    Nov 16, 2009
    australia
    What engine in what type of truck????
  5. red211
    33
    tn
    Dang, sorry bout that, it's in a 93 LTL 9000 Ford, 60 S 370/430 set at Detroit for 425 to 1800, 400 1800 to 2100. Put a water pump in last fall, but would a water pump pressurize the tank in 3 minutes?
  6. ranga
    16
    Nov 16, 2009
    australia
    By-pass your air comp. By blanking off both coolant inlet and outlet on engine side and attach a garden hose to either in or outlet on air comp. - u may want to put a hose clamp on it to prevent in coming off, turn hose on and check the flow then when u r happy with it start engine and re-check header tank,(depending on how much coolant u lose when blanking off coolant from engine u may want to top up header tank level) if u r unsure attach anoter hose to other side where water is coming out and run it into a bucket, hold hose end under the water and look for air bubbles - if u c air change out air comp. Also check your air tanks for any signs of coolant.
  7. USMC379 PETE
    USMC379 PETE Bobtail Member
    23
    34
    Jan 27, 2011
    NC
    This sounds just like a problem we had at one of the companies i used to turn wrenches at. The driver said coolant was blowing out like crazy so he had to deadhead 100 mi back to the shop. We started checking everything we could think of. It started getting hot in the cab so i turned off the heater after a while we still couldnt find anything and it was still hot in the truck so i turned off the bunk heat. The problem was that the truck was a volvo! Volvo used air to control the coolant to the bunk and the valv went bad and the air was going into the cooling system and blowing it out the tank. I do not know if ford uses air control valves like that or not. I would say the air comp. is another good place to check.
  8. red211
    33
    tn
    Thanks for the replies, this had a sleeper but the p.o. removed it and added a dump bed. I hate that part but it was a really cheap dump compaired to a factory built one. I will check to see if the valve for the bunk is under the cab and blocked off or removed with the bunk. I was thinking the stuck thermos caused the overpressure and cracked tank, but it didn't have time to heat up any and was blowing coolant everywhere this morning so I am leaning to the compressor, but what goes bad to blow air into coolant?
  9. mslashbar
    mslashbar Medium Load Member
    602
    813
    Jul 22, 2009
    elizabeth,co
    The air compressor has its own head gasket, which will be bad if you're getting air in the cooling system from the compressor.
  10. red211
    33
    tn
    Would you put a new head gskt on the compressor like an engine or get a reman compressor? Do the heads warp and crack like an engine or just stick a gskt on it and go?
  11. mslashbar
    602
    813
    Jul 22, 2009
    elizabeth,co
    You'd have to pull it apart and inspect the head. Also depends on what brand compressor you have as to weather or not you can find a head gasket.
