Have you seen tandem tire do that?
Discussion in 'Ask An Owner Operator' started by czego82, Nov 5, 2019.
  1. czego82
    czego82 Light Load Member
    160
    44
    Nov 15, 2014
    All tires are in good shape except one.
    It is Forward axle right side, inner tire on the tandem.
    Any idea what is causing it? I figured if it was the alignment then I would be loosing both tires on that side not just inner...
  3. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Been run flat for a good while looks to me.
    Rideandrepair, tinytim and mhyn Thank this.
  4. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,080
    Sep 24, 2019
    Raleigh, NC
    When was the last brake job done ( including S cams )?
  5. Dale thompson
    5,175
    43,370
    Nov 20, 2013
    commerce twp,mi
    Serious under inflation is my best guess.
  6. Ridgeline
    22,414
    116,600
    Shocks first, then bushings. Then alignment.
    Rideandrepair Thanks this.
  7. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    Yeah- He doesn't want to keep running it like that,Puts extreme wear on cam Bushings and Axle Spider/Housing where Bushing will Egg Out inside, All that Bouncing up n down You may Not feel it in the seat...But Its tearing your axle/Brake Hardware up Bad.
  8. czego82
    160
    44
    Nov 15, 2014
    Before we got this truck. brakes look good. Plenty of meat left.
  9. czego82
    160
    44
    Nov 15, 2014
    All 8 are at 100psi and checked regularly
    tinytim Thanks this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Shocks, springs, suspension, brakes and it's hardware first. Alingment next.
    Throw that tire away, put two good ones on that dual. Keep the other old as a spare for now.
    Your truck is hurting real bad back there. And it will continue to tear em up until you find the root cause of the problem within the rig.
    Idahojoel Thanks this.
  11. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    And then, sometimes it is just a blemished tire. Some tread patterns are worse than others for this too.
    tinytim and Rideandrepair Thank this.
