Having trouble down shifting
Discussion in 'Questions From New Drivers' started by Lame Duck, Sep 25, 2012.
  1. Lame Duck
    Lame Duck Bobtail Member
    22
    Sep 9, 2012
    I'm a student just started r road trips passed my skills no problem I thought that would be the hardest part but I can't down shift to save my life I can double cluch up though the gears no problem but coming down well that's anothere thing all togethere after today there cant be many teeth left on the ten speed I was driving I sure hope that practice make prefect or Im in trouble.
  3. Sly48
    Sly48 Light Load Member
    132
    31
    Jun 28, 2012
    Houston, Tx
    My only advise is to learn your speeds for each gear.... IE: 1st-3mph, 2nd -6mph, 3rd - 9 mph, 4th - 12 mph, 5th - 15 mph, 6th - 20 mph, 7th - 25 mph, 8th - 35 mph, 9th - 45mph. 10th- 55+ mph. Most new drivers try to downshift before the proper speed and RPM and end up grinding gears. RPM's down to 1000, clutch, 1500 RPM's, clutch, Gear. Unless your skip shifting...then rpms down to 800.
    I had a funny instructor....he would also say.... upshifting - Left Foot, Left Foot, Floor ......downshifting - Left Foot, Right Foot, Left Foot, Floor...hahaha!!! He would also make us say....what gear I'm in...and what gear I'm going to. It worked!!
  4. Joker85
    Joker85 Road Train Member
    1,465
    331
    Jul 3, 2010
    Phoenix Az
    also depends what the trucks are rated at i have a 13 spd and my rpms are 1100-1350. Try floating em down shifting
  5. Lame Duck
    22
    Sep 9, 2012
    Today was the first time on the road but I will try that tomorrow and I got to eat some crow I used to tell my buddy that anyone can drive a truck tjat there was nothing to it but I WAS WRONG!!!!!!
  6. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    If you have the typical 10 speed Fuller Eaton, downshift by your speed primarily, Remember 45, 35, 25, 15... 4+5 = 9, when you drop below 45 downshift to 9th, 3+5 = 8 when you drop below 35 down shift to 8th, 2+5 = 7 so below 25 to 7th and 1+5=6 so below 15 to sixth... when coming to s top, stop in sixth, go to neutral drop the range selector and go back to 2nd 3rd ir 4th which ever you are starting in... Climbing you should be able to pull most any mountain in hi range so 6th should be the lowest you need to down shift to.
  7. KMac
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    Oh, and yes you do need to raise the RPMs to 1400 - 1500 when you down shift, those speeds are only for when to come out of gear, have to give the throttle a little nudge when going into the lower gear.
  8. wetwelder
    wetwelder Bobtail Member
    12
    Sep 15, 2012
    wow, i didnt know they still taught double clutching,, i never learned it, i did try it once , didnt work, but you have to learn what gear your in at what speed an know your rpm range, go into sanfrancisco rush hour traffic, you will learn real fast, , good luck,,
  9. Lame Duck
    22
    Sep 9, 2012
    Yes it a fuller eaton and that make it easy to remember thanks I will give that a try cuz it's got to be better than what I'm doing.
  10. Lame Duck
    22
    Sep 9, 2012
    I know u need three feet one for the clutch one for the brake and one for the gas lol....
  11. KMac
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    Good Luck and have a little faith man, you'll get it... its a rhythm is all... Up shift is clutch neutral clutch gear, down shift clutch neutral rev clutch gear... anyway once you have your CDL and hit the road with a trainer you will learn to float, that just means you won't be using the clutch, the shifting part and road speed, engine speed all that stays the same, just no clutch so concentrate on getting you downshift speeds and reving to the right RPM to go back into gear and you'll be fine.
    Have a little faith.
