When my new instructor went through the pre trip he went through it really fast. Then we started doing are driving around the parking lot/ course. I feel I am in no way ready for the pre trip test with an IL dmv tester. I need to know if there is a better way to study for the pre trip than the cdl book? I've been looking on you tube ect.
Any suggestions on how to pass pre trip here in ILLINOIS?
Having trouble with my Pre Trip for school
Discussion in 'Questions From New Drivers' started by Cypher, Jul 26, 2009.
This was one day? You should be pretripping every day for the entire 4 weeks.
luvtheroad, Darkschneidr, Texas-Nana and 2 others Thank this. -
just continue to practice everyday. skip lunch, practice. we had a cd to listen to if we wanted to and pics with the discriptions. get another person and take turns helping each other. again, practice.
i can tell you if you don't you'll fail the pretrip and have to take it again.Texas-Nana Thanks this. -
Memorize it in sections...front of truck, middle of truck, rear of truck, front of trailer, middle of trailer, rear of trailer, inside cab, brake pump down.
Worked for me that way...Biscuit75, luvtheroad and Baack Thank this. -
you've only got thirty minutes to do the entire tractor and trailer so there isn't much time for overkill in my opinion and if you have a crappy examiner...
What I did was to take my digital camera with me, and I took pictures of everything on the pre-trip. Under the hood, behind the tractor, hook ups, parts and area of the 5th wheel, suspension of the trailer, don't forget the inside of the tractor, the dash etc. Anything and everything. Have all the pictures printed out on a printer. On standard sheets of paper. Label or number every part to be checked. I studied mine at home/motel room at my leisure. No stress. My instructor said that it was a very good idea I had. He had never seen anyone do it before. I blew through my pre-trip test with no problems or errors or hesitations. I use the same idea when I have to take apart something, and I question of how it goes back together. Last week I had a major electrical problem with my Honda Goldwing. I took many photos, printed them out, and everything went back together as it should have. Just an idea on how to work out your pre-trip problem. If the instructor won't let you photograph the truck being used in class, you might explain to a driver your situation and he/she might let you photograph the areas of his truck. Good luck.
luvtheroad Thanks this. -
I practiced my pretrip every morning before class, but then when I got home, I went through the guide and came up with my own quiz of sorts. Basically I numbered out every part I was supposed to mention, then I started at the "front of the truck" and wrote down every part in order. If I missed one, I started over. Once I had completed the whole list, I no longer needed the paper and I could do the pretrip easily.
Don't be too intimidated by that part though, lol, as that one isn't the one that gets most people. The #### 7 step air brake test almost got me, I mean came within seconds of it, and I happened to remember I forgot my tug test. -
You attend school everyday and have access to the equipment, right? So you show up 30 minutes early and practice or stay after and practice. Whatever it takes. As a former instructor, I had my students doing pre-trips constantly and I would mix it up. Sometimes before, sometimes after driving. Sometimes with the cheat sheet, sometimes without. Sometimes starting at the midway point,etc. On DMV test day, they knew their stuff, forwards and backwards...... Yeaaaaaaah
