Haz-Mat Test - am I ready to take it?
Discussion in 'Questions From New Drivers' started by tdriver196, Jul 17, 2012.
  1. tdriver196
    tdriver196 Light Load Member
    79
    12
    Jun 18, 2012
    I have been reading the book from the NC DMV, and doing the online practice test on this site and consistently passing. Am I ready to test or should I keep studying or do online test elsewhere first?
  3. Bishop73
    Bishop73 Light Load Member
    81
    22
    May 8, 2009
    Central Texas
    If you aren't having problems with those tests you should be fine. You will likely see the exact same questions on the DMV test, some may be worded a bit differently but same questions. I read through the Hazmat section and then just did online practice tests for a couple days, I think I missed 1 on the test.
  4. dptrucker
    dptrucker Road Train Member
    4,681
    3,197
    May 14, 2012
    adelanto,ca.
    only you will if your ready or not. just go take untill you pass. good luck
  5. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    I studied once and it was the.night before the test and I had the flu. I passed easily
  6. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    you're allowed several wrong answers, and you can take it up to three times in a day. I don't think you'll have any trouble passing.
  7. NotFastEnuff
    NotFastEnuff Bobtail Member
    23
    9
    May 15, 2012
    Knoxville, TN
    I don't know where you're from or NC's laws, but in TN, you have to wait 7 days if you fail it. Been that way since '05.
  8. Klatu
    Klatu Road Train Member
    1,039
    230
    Nov 26, 2010
    Argyle, TX
    If you passed an online test, you're ok to go. Just remember to take it slooooow. They use trick questions. Most are easy, simple questions. They are multiple choice. They change the words in a way you're not used to. They will try to trick you. I think I missed one. Then you have to go get fingerprinted. If you are a felonious person, don't go. You have to go through Homeland Security as well. I believe Texas only allows to test once a day for that if you fail.
  9. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    I have to renew my hazmat. I looked at the tests this site has posted. They are ridiculously stupid compared to what is on the Illinois hazmat test.
    Try CRST'S site for more realistic testing.
    Mikeeee
  10. FozzyNOK
    FozzyNOK Road Train Member
    2,459
    3,786
    Jul 18, 2007
    Oklahomistan
  11. EnigmaGal
    EnigmaGal Light Load Member
    73
    35
    Jul 17, 2012
    NY
    Thanks, PMRAcing and FozzyNOK...those are really good sources
