HazMat in Canada
Discussion in 'Trucking Industry Regulations' started by tbdieseltrucking, Jan 11, 2017.
  1. tbdieseltrucking
    tbdieseltrucking Light Load Member
    100
    60
    Jan 4, 2017
    Stuck in a Rut
    Looking for some information on border crossing. I have never been into Canada, but have 2 opportunities in a new owner operator position to go there. The nature of the work takes the company there, so not going isn't an option. One would be HazMat tanker, and the other would be non Haz tanker.
    I don't yet have a passport, so wanted to find out how that process works. Also, FAST card...do I need that? Border crossings would be in VT, NY. Also, there is nothing on my record to prevent me from entering Canada. Thanks in advance.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Passport certainly. Enhanced drivers CDL as well as whatever else you need.
    You will be dealing with Customs at the border, that is the biggie. The paper work has to be in order before you get there. Expect to spend time at Customs.
    Do your math in meters instead of feet and inches. That means 4 meters equals 12 feet for overhead bridges. And your speeds will be in kilometers per hour. 100 is roughly 60 mph.
    If the scales are open you cross them. They can weigh american just as well as count in Canadian lol. Just don't need as many numbers on their fingers and toes.
    tbdieseltrucking Thanks this.
  4. tbdieseltrucking
    100
    60
    Jan 4, 2017
    Stuck in a Rut
    Thank you @x1Heavy.....loads will be HazMat, so paperwork will have to be in check. The company I may pull for goes there regularly. MA as of right now does not have an enhanced license. I was told to get a passport card, versus full passport...Idk...also what is/do I need FAST card?
    Finally my tractor is 260" wheelbase, does that present an issue? From what I know, Canadian trucks are only allowed 244"?
  5. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Disclaimer: I haven't hauled hazmat in a very long time, but here is some starter info.
    Attention, hazmat haulers hauling into Canada: The federal transportation ministry no longer accepts a hazardous materials endorsement as the sole evidence that a driver has completed necessary training.
    Additional proof is now required in the form of a certificate of training, according to Transport Canada. These certificates, obtained at the completion of required training, must be available to show to inspectors, said Transport Canada Spokeswoman Maryse Durette.
    “Canadian legislation requires that a person who handles, offers for transport, or transports dangerous goods be adequately trained and hold a training certificate. Their training certificate is their proof of training and must be provided to an inspector upon request,” Durette told Land Line on Thursday, Oct. 1.
    The requirements for U.S. drivers are set out in section 6.3 of Part 6 of the Transportation of Dangerous Goods Regulations.
    http://www.landlinemag.com/Story.aspx?StoryID=18264#.WHY7uHGp62e
  6. tbdieseltrucking
    100
    60
    Jan 4, 2017
    Stuck in a Rut
    @not4hire Thanks....that info sounds about right. I have HazMat, tank, and my TWIC. Also have a card from company stating I have done training. Most likely this job would have a similar card, as this new position would be hauling HazMat that I haven't done yet. Been all 1203, and 1993 so far. This will be 1075. Thanks for your reply.
  7. wis bang
    wis bang Road Train Member
    3,455
    4,099
    Jan 12, 2011
    Levittown, PA
    When I worked for the US office of a Canadian carrier, our operators w/ long wheel bases were not bothered except when the spring thaw [frost laws] leads to reduced weight ratings as the US tandem spacing is closer than the normal spacing on Canadian trucks so the axle weights are lower...
    The passport card is convenient for frequent crossings.
    Haz Mat shippers usually have their border crossing stuff well in order and usually cooperate letting you fax a barcoded document for pre-clearance. I know that the bar-code process has changed some but it was still the best way through customs.
    Also make sure you have am inward manifest filled out for US customs on your return...and buy the decal for un-limited crossings instead of paying the $5.00 fee every time you return to the states...
  8. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    A FAST card is only good if the load, carrier and driver are all FAST loads, otherwise it doesn't apply. However, if it does, it will assist you at the busier crossings.
    Yes, 244" is the maximum, but longer is allowable to greater or lesser degrees depending on where you go. At worst, it requires a permit and the tractor-trailer combination must meet maximum length limits.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Also they are called "Danderous Goods" in Canada as opposed to hazmat.
    If you see the following signs it is referring to trucks hauling dangerous goods:
    Green = good to go
    Red = cannot go even if it is a truck route.
  10. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
  11. tbdieseltrucking
    100
    60
    Jan 4, 2017
    Stuck in a Rut
    Good to know...thank you.
