Hazmat must stop at scales?
Discussion in 'Questions From New Drivers' started by Zephex, Aug 21, 2014.
  1. Zephex
    Zephex Light Load Member
    161
    112
    Jul 8, 2013
    Blue Ridge GA
    When I was with my trainer, he told me there were a couple states that you HAD to cross the scales if you were under a hazmat load. REGARDLESS of what the prepass light said.
    Is this true? Which states are they? How would I have known this without finding out the hard way since it is not on any kind of Hazmat test or anything....
    Not sure if its true or not, but Id hate to get the green light, then get one big ticket 10 miles down the road when they send a chaser for me which would probably also include a very extensive inspection.
  3. 48Packard
    48Packard Ol' Two-stop Shag!
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    Your PrePass guide will have those answers. Ohio comes to mind right off the top of my balding little head.
    double yellow Thanks this.
  4. 48Packard
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    double yellow, HotH2o and Snowshoes Thank this.
  5. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    48Packard Thanks this.
  6. 48Packard
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    Yes, thanks for the notation on the AUHP....I always seem to forget about that...seems I just forgot about this a few weeks ago!:biggrin_25523:
  7. realsupatrucka
    realsupatrucka Road Train Member
    2,072
    513
    Sep 25, 2013
    houston tx
    I thought it was Virginia not west Virginia
  8. Dewey120
    Dewey120 Road Train Member
    1,025
    456
    Mar 17, 2010
    Southern California
    I know Arizona is one you have to stop at with hazmat even when you get the green light. But this does bring up another question. When pulling hazmat through Arizona and those two lighted signs before the scale say 'truck bypass weigh station' can you keep rolling or should you stop anyway?
  9. 48Packard
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    See the link I posted above...it gives the AZ specifics near the bottom.
  10. kemosabi49
    10,594
    45,304
    Jan 13, 2013
    SW Arkansas
    Arkansas and Arizona are the ones for sure. Ohio and some others if hauling fuel without state permits. You should be able to get a PrePass pamphet from your company and at most state scalehouses if you happen to have to go inside anyway. Or online at PrePass.com
  11. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Also be sure to read signage approaching the scale. More then a few states will instruct ALL HM haulers to cross the scales (if open). And I assume they mean to "Cross The Scales", regardless what pre-pass and the initial weigh-in-motion director says.
