hazmat question
Discussion in 'Ask An Owner Operator' started by bertlog, Oct 21, 2013.
  1. bertlog
    bertlog Bobtail Member
    Is there an industry standard on how much to up charge for hauling hazmat? Is it 20 cents per mile more?
    Bert
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Depends on how dangerous it is and if I will need to change my route or not to accommodate. I norm got paid .05/mile more but if its something major then tons more.
  4. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    What major hazmat have you hauled if you don't mind me asking?
  5. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Not much "Major".
    I hauled a lot of flammable 3, (always roofing glue at TMC, not that bad) ...the rest all varied, never the same thing twice. Mostly stuff that's not bad, but some corrosive, highly flammable, inhalation hazard, toxic once...never explosives or radioactive. Personaly i dont like hazmat unless it pays well enough with little inconvenience. When I was with landstar I picked the loads and could negotiate. If I had to run more miles do to hazmat restricted loads I'd need more then .05 more. At TMC as a company driver we made $35 extra / load. I've hauled methanol a few times and that is dangerous stuff. I wouldn't need to make as much carrying photo solution to fugi film as i would methanol to a manufacturing plant.
  6. LSAgentOZR
    LSAgentOZR Road Train Member
    2,043
    1,354
    Nov 1, 2011
    Nashville, TN
    Standard charge is $150 for Class 2, 3, 4. Higher than that, and it depends what it is.
  7. JD56
    JD56 Bobtail Member
    28
    8
    Mar 8, 2012
    NJ
    How long does it take for the Hazmat fingerprints and background check to take and get a notification so I can go to DMV and take the test?
  8. LSAgentOZR
    2,043
    1,354
    Nov 1, 2011
    Nashville, TN
    Not sure, but while you're at it bite the bullet and go get your TWIC and TSA as well. Don't let there be a limit on where and when you can pick up or deliver loads. The Hazmat background check and fingerprints qualify for your TSA stuff as well, which allows you to pick up time critical air freight (i.e. better rates.)
  9. flood
    flood Road Train Member
    4,167
    4,045
    Dec 25, 2010
    each state does it THEIR way.... in TN. you have to take the hasmat test and after you pass THEN they send you to get the background done
  10. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Wow, i've been getting ripped off then.
