Flatbedders - I have a new conventional tractor being delivered - I will be putting a APU on the right side and also mounting a head ache rack- The problem - The mounting brackets for the APU go across the top and bottom of the frame rail - Right where the rack foot needs to go - I don't think I want to cut slots or holes in the I beam channel - or use a 2" spacer the length of the rail (26") - I am sure some of you have run into this - Any ideas, thoughts, suggestions are welcome - And I Thank you all
Head ache rack and apu install
Discussion in 'Flatbed Trucking Forum' started by FLT 76, Feb 4, 2014.
I would mount a plate between both mountings, against the frame and continue it past the back end of the head ache rack, Use the bracket you cut off to mount it on the left side of the bracket. Make the plate you use at least 6 inches so it will not flex, and the thickness of the mounting feet.
Just a thought! -
just notch it out, its what I did . never had a problem, its a common problem mounting racks.
I would notch the foot of the headache rack also.
Any time you modify a safety related piece you risk, the inspection pigs condemning it, some engineer designed the headache rack to do a certain job as it is, if you change anything then it is no longer certified. I am also a licensed inspector.
Just a thought! -
well since a rack is not required by the feds, only by some companies. the thought is it shouldn't be a problem for an inspector,
On top of that most of the so called headache racks have stickers on them saying they are not a safety device and should not be considered a front end structure or headboard.
Shim it. What ever the thickness of the mounting bracket of the apu take 2 plates of steel lay them on top of each other weld them obviously on the driver side you can use 1 section passenger side 2 or 3 cut. Make sense I can see it in my head. But am not a good explainer
explain that on the inspection as a headache rack isn't required by the feds , although some companies require you to have them. I have mine notched and have had inspections with never a question about it.
sometimes folks make mountains out of mole hills. just notch the dang thing and get to work already.
it may void the warranty from a defect or a crack from the manufacturer, but it darn well isn't a inspection violation. as I said hard to violate something that isn't required by fmcsamc8541ss Thanks this.
