head light problem
Discussion in 'Peterbilt Forum' started by joe jr, Sep 25, 2012.
  1. joe jr
    joe jr Bobtail Member
    mass
    I have a 02 pete, the problem is my headlights work fine until i put my highbeams on. The drivers side works as it should, but there is no power at all to the passenger side on highbeam. I've checked the ground is good it seems there is no power to the fuse box from the steering colum i just thought someone else maybe has had the same problem and could give me a shortcut to save me some grief! Thanks. Joe jr.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    There should be a jumper wire from one highbeam to the next. I would suspect a poor connector or a broke wire where it enters the connector. Back up a couple inches and back probe the wire and see if there isn't power. Double check the ground connection for corrosion. That's the only thing it can be if one side works. I have run a new chassis ground before.
    Here's a schematic that might help, page 17. You have to zoom in to read them. Use your toolbar.
    Go back to the main page to find other schematics.
    http://www.supermiller.com/pdf/P94-6023.pdf
    That particular model runs through a MFTS module but your problem has to be between both lights.
  4. joe jr
    mass
    Condocruiser, thank you very much, iwill check it out and let you know what i come up with. I am pretty lucky cause,i know most of the dot in mass and nh ,i just want to fix the problem in case i do get pulled over. Anyway thanks again for your help. Joe jr.
  5. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    I had the same issue on my 99 pete but turned out to be the relay in the door down by left foot. Mine apprantly has separate relays for left and right high beam headlight. I switched the relay out and haven't had the problem since.
  6. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I had the same problem with the same fix. Swapped relays and all is good so far.
