headboard/cab rack
Discussion in 'Trucking Industry Regulations' started by DL550CAT, Nov 2, 2010.
  1. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I have a question. Do you need to have a headboard or cab rack if pulling a flatbed trailer? I see lots of trucks out there with out them but always heard they were required.
  3. Chain Drive
    Chain Drive Medium Load Member
    436
    113
    Nov 28, 2008
    Nova Scotia,Canada
    it's pretty gray in the rules, but if you plan on needing chains, you'll be glad you have one, and with winter coming, I've seen lumber slide forward even with lots of straps stuff can slide forward, and a new $500 rack is a lot cheaper than a new bunk
    DL550CAT Thanks this.
  4. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    No, it's no longer a requirement.
    Chain Drive and DL550CAT Thank this.
  5. DL550CAT
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I put a box on the front to hold chains and binders in. I took the headboard off cause my driver has ms and was having trouble getting around it. I was wanting to make sure I did not need to get a cab rack.
    The driver does not want a rack. He has to blindside into his driveway and even the racks with windows the visabilty is not that great when you get into a tight spot.
  6. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    I always thought they were required but saw more and more guys without them so I asked. Wish I would have known that earlier because we had a guy leased on with us with a LONG 379 and we had a customer that had loads of 60' beams weekly we could have hauled with it but didn't he didn't have a headache rack so I turned the loads down. Live and learn I guess.
  7. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    You do not need a headboard ,but if you do not have one you need an extra chain or strap in the 1st 8ft off the load or 2 on the 1st pallet.
  8. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    I forgot about that. Same rule if the load is more than like 4' from the bulkhead.
  9. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    Nothing grey about it...it's not required.
  10. Scott Mac.
    Scott Mac. Bobtail Member
    40
    10
    Jan 26, 2008
    New Haven, MI
    I always thought that if you didn't have one you had to build a temp bulkhead infront of the load.
  11. dieselbear
    dieselbear Road Train Member
    1,798
    2,800
    Oct 18, 2008
    Here's the regulation if you are using the front end structure as part of the securement system. If I were driving these loads I would have a headache rack. Some of the wrecks I have seen, I've seen some headache racks stop a piece of cargo from going into the cab. Had a log hauler a few years ago that had a log come through the back of the cab and struck him in the head. But like many have posted they are not required.
    §393.114 What are the requirements for front end structures used as part of a cargo securement system?
    (a) Applicability. The rules in this section are applicable to commercial motor vehicles transporting articles of cargo that are in contact with the front end structure of the vehicle. The front end structure on these cargo-carrying vehicles must meet the performance requirements of this section.
    (b) Height and width. (1) The front end structure must extend either to a height of 4 feet above the floor of the vehicle or to a height at which it blocks forward movement of any item or article of cargo being carried on the vehicle, whichever is lower.
    (b)(2) The front end structure must have a width which is at least equal to the width of the vehicle or which blocks forward movement of any article of cargo being transported on the vehicle, whichever is narrower.
    (c) Strength. The front end structure must be capable of withstanding the following horizontal forward static load:
    (c)(1) For a front end structure less than 6 feet in height, a horizontal forward static load equal to one-half (0.5) of the weight of the articles of cargo being transported on the vehicle uniformly distributed over the entire portion of the front end structure that is within 4 feet above the vehicle’s floor or that is at or below a height above the vehicle’s floor at which it blocks forward movement of any article of the vehicle’s cargo, whichever is less; or
    (c)(2) For a front end structure 6 feet in height or higher, a horizontal forward static load equal to four-tenths (0.4) of the weight of the articles of cargo being transported on the vehicle uniformly distributed over the entire front end structure.
    (d) Penetration resistance. The front end structure must be designed, constructed, and maintained so that it is capable of resisting penetration by any article of cargo that contacts it when the vehicle decelerates at a rate of 20 feet per second, per second. The front end structure must have no aperture large enough to permit any article of cargo in contact with the structure to pass through it.
    (e) Substitute devices. The requirements of this section may be met by the use of devices performing the same functions as a front end structure, if the devices are at least as strong as, and provide protection against shifting articles of cargo at least equal to, a front end structure which conforms to those requirements.
