Ok so i got my hands on a set of clear halogen 4x6 headlights. They have a replacable h4 bulb. Now the issue i run into is when in plug these in. It keeps the high beams on all the time. If i reverse the ground to the center prong and and the red to the outside. Then it seems to work where the high beam doesn't stay on but is very dim until i hit the high beams. Also in any position. The low beams and high beam elements are lit in the clear bulbs. Plus i get a low beam fault. Has anyone done one of these trucks and can give me a schematic. Or wiring diagram
Headlight conversion 13 kw t800 issues
Discussion in 'Kenworth Forum' started by Scottman25, Jan 15, 2017.
Have you measured the wires?
Are you shure that ground is ground?
Have disconnected the other side off the truck? -
I will look into that. The low beam side has green red and black. The high beam side has green and red. The green and red seem to branch off and come from the low beams plug.
H4 bulbs have a different wire configuration that regular headlights. You'll need to repin your harness or buy a conversion harness.
http://www.rallylights.com/hella-adapter-from-165mm-sealed-beams-to-h4-conversion-lamps.html
