Headlight problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mississippi129, Dec 5, 2018.
  1. Mississippi129
    Mississippi129 Bobtail Member
    11
    Dec 5, 2018
    Headlight problems
    I have a 94 Peterbilt 379.
    When driving on a rough road, the lights flicker. Even if the switch is turned off. Any ideas?
  3. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    I'd put my money on a bad switch if it's doing it with the switch off
  4. AModelCat
    161,908
    I'd consider a short to power. Check for rubbed wiring on the harnesses.
  5. Ridgeline
    22,650
    120,894
    The cable from the frame to the hood may be bad.
    Doubt it is a switch.
  6. Diesel Dave
    9,333
    30,144
    Jan 20, 2010
    Hesperia, Ca.
    Check the relay on the circuit box. The relay can get hot. Check the pins on the relay, clean them or change for another relay on the panel. Most of the relay on the panel are the same. I have the the same make and year of your truck. And have had a similar issue. The toggle switch may be an issue also but I never had it with mine.
  7. Mississippi129
    11
    Dec 5, 2018
    You were right!! I put in a new switch this afternoon... so far so good!! Thanks for the input y’all!!
  8. Mississippi129
    11
    Dec 5, 2018
    Thanks! It was the switch. I’ve had a lot of people tell me I should “update”, but the old girl is paid for. I frame about 300,000 ago. New 13 speed transmission less than a year ago... I think I will keep my seat.
    Diesel Dave Thanks this.
  9. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Update for what? A newer and high dollar headache. Them computer mechanics at the dealerships would never have found that. Keep what you got. Be happier.
