Apparently I have a low beam fault. Drivers side headlight is out. Need a recommendation for some lamps that will turn night to day. I don't see as well at night as I should and so anything that will blind oncoming traffic is probably exactly what I need. Cost irrelevant.
2016 Kenworth t680.
Headlight recommendation?
Discussion in 'Questions From New Drivers' started by RedRover, May 17, 2017.
Page 1 of 3
JW Speaker make some that will fit they are plug and play
RedRover Thanks this. -
I mean one is out, I don't think they sell them in single packs and I might as well get the best ones I can. -
Swift uses the same quality DOT certified bulbs everybody else does, you should have picked up spares at a terminal. What did truckers do years ago with those 35w sealed beams; hard to imagine freight ever got delivered?Last edited: May 17, 2017
AModelCat Thanks this.
I was being sarcastic you ########. Looking for the best and brightest. Not going to go round and round with folks who probably have those annoying ### blue spectrum bulbs in their own #### anyway.
Do you have a headlamp recommendation? If not, you can scroll on.
#### sake. Yea man I totally legitimately want to literally blind people. Because what could be safer for me on a two lane road like 287 to Texas from Colorado that I run all the time than actually blinding oncoming traffic. -
All the bulbs you buy over the counter are going to be the same DOT spec. If you want to try to waste your money on something "special" go knock yourself out and waste your money. Any coating put on the bulb is going to make it dimmer.
Lepton1 Thanks this.
Page 1 of 3
