Headlight small marker lights
Discussion in 'Trucking Industry Regulations' started by Knobs1957, Aug 24, 2017.
  1. Knobs1957
    Knobs1957 Bobtail Member
    17
    13
    Jun 25, 2017
    I have a 2014 t 680 and there are two small marker lights in the headlight assembly one in each assembly.
    They are between low beem and high beem.
    Our mechanic told the office they are only there for looks and they don't need to work.
    I told them that if it's there dot will write me up if they are not working.
    Any feedback would be helpful.
  3. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    They are not required by DOT. Only required lighting is required to be operational.
  4. Knobs1957
    17
    13
    Jun 25, 2017
  5. mitrucker
    mitrucker Road Train Member
    5,420
    10,045
    Dec 15, 2010
    Lapeer, MI
    Those bulbs cost 0.25 each and take two minutes to replace.
  6. Knobs1957
    17
    13
    Jun 25, 2017
    I know that I did replace them. Still not working the mechanic looked said it can't be fixed. So he took out the bulb on the good side.
  7. mitrucker
    5,420
    10,045
    Dec 15, 2010
    Lapeer, MI
    Sounds like a wiring harness issue.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    And to specify, so it's not just truck stop rumor....
    eCFR — Code of Federal Regulations
    §393.9 Lamps operable, prohibition of obstructions of lamps and reflectors.
    (a) All lamps required by this subpart shall be capable of being operated at all times. This paragraph shall not be construed to require that any auxiliary or additional lamp be capable of operating at all times.
    The words of wisdom, I highlighted.
    Dye Guardian and Studebaker Hawk Thank this.
  9. jamespmack
    216,333
    They may not be able to cite you, however it doesnt stop them from pulling you over or behind scales because its inop. I run legal required lights only, and make sure they work. Them extra chicken lights look nice. But not on my truck amd trailers.
  10. Knobs1957
    17
    13
    Jun 25, 2017
    There's are not chicken lights.
    They are a small marker light inside the headlight assembly. Mechanic said he couldn't fix the one after replacing the bulb.
    So he left it out and then took out the working marker light out of the good headlight assembly.
    I agree I always try to keep all lights working.
    That's why I posted the question he's told the office they were there just for looks. I called bs on that
