Hi all.
Engine fan in my Kenworth/Cummins/probably about a 2013 truck doesn't shut off anymore. Pulling overweight, so hours of 1800-1900 rpm and that fan really roars. Been a few weeks (trying to get shop to fix it) and I've noticed that something in the pitch of that fan really hurts my ears after a while. My wife says I'm yelling without realizing it and my ears feel stuffed with cotton, so I'd better do something. Started using regular foam ear plugs from the shop and they block too much sound. Are all foam earplugs the same? Can I find some that don't block quite as much? Has anyone found a solution for ear protection while driving other than foam plugs?
Hearing protection until they fix engine fan
Discussion in 'Experienced Truckers' Advice' started by J Man, Oct 16, 2017.
It's probably a loose connector or air fitting somewhere and probably a relatively easy fix once you find the problem causing the fan clutch to remain stuck in the engaged position. Shut off the engine, then turn the key to the on position (don't start), then carefully listen for leaking air under the hood, or fiddle with connectors and harnesses and see if you can hear the clutch disengage.
Is the AC button off? (maybe the AC or defroster system is faulty and calling for fan to be on) This can sometimes be caused by having a refrigerant leak or otherwise too high pressure in the refrigerant systemJ Man Thanks this. -
ChaoSS Thanks this.
All I can think of is get the truck fixed. Probably not the best idea to be wearing ear protection while driving, IMO. As I have flashbacks to screaming back and forth to my dad in the passenger seat in the old GMC Brigadier 6-71 Detroit with no muffler. LOL Have you tried cotton?
And the engine fan did run normally if the AC is maxed out, its summer time or I'm pulling a hill. But this thing won't shut off even when I'm coming home empty at 3am and the engine temp is down below 170. That is when it gets to be unbearable, when the motor is quiet, the world is quiet, and its cold out and still roaring away like a lunatic going through town.
