Heat. How how hot does everyone allow? Tire heat sensors?
Discussion in 'Experienced Truckers' Advice' started by Charlie42, Jul 23, 2023.
  1. Charlie42
    Charlie42 Light Load Member
    85
    152
    Jul 1, 2021
    It’s 113 in Stockton area right now and my tire sensors are beeping all over the place. Guessing the 5 asphalt is probably 250-300?. Heavy load and just pulling over at a flying J. I know humidity and rain play a big factor, but straight beat down sun, anyone know the safe temp to stay under? I typically only drive at night in the summer, but have a load that needs to get to Redding, so any feedback would be great
    austinmike Thanks this.
  3. Concorde
    Concorde Road Train Member
    5,261
    18,429
    Jun 29, 2016
    West Melbourne Florida
    I’m just east of you (Florence, SC) and I just had my heat on for a few minutes :)
    I can’t answer your question but always preferred driving at night during the summer. One reason was to minimize the tire wear due to the daytime heat.
    Charlie42 Thanks this.
  4. Brandt
    Brandt Road Train Member
    4,601
    6,314
    Sep 17, 2012
    I never heard of heat being any problem. MD Alignment guys said before the tires good till about 400 PSI the aluminum rims will fail before the tires do. They said the hotter the tires the less flexing the side walls do because of more air pressure. Running the tire on low air pressure mean the sidewalls flex more and build up for heat till the tire fails. They say 113F plus the payment even being hotter was not a problem for the tires.
  5. skallagrime
    skallagrime Road Train Member
    3,853
    9,925
    Apr 10, 2012
    Indiana
    Assuming perfect tires with known history and no sidewall dmg...
    Lotta assumptions to make especially if hes got a company trailer...
    Charlie42 and W923 Thank this.
  6. W923
    W923 Road Train Member
    1,387
    4,260
    Feb 28, 2022
    I don’t know that you have to worry about them falling if they’re in good condition and properly maintained. I know we had a high school kid mounting tires a few years ago and he used ether on a 315…he had enough pressure in there to blow the Teflon seals out of the clip on air chuck. I hesitantly ran that tire till it was bald and never had a problem.
    Feedman, Charlie42 and ducnut Thank this.
  7. ducnut
    ducnut Road Train Member
    2,587
    7,807
    Dec 31, 2010
    SPI
    You’re overthinking it.
    @Brandt is 100% correct about sidewall flex and pressure gain. Underinflation and speed put a huge amount of heat into a tire, due to sidewall flex. In contrast, a couple weeks ago, I had a blowout on a trailer with about 11K pounds on it. Every tire was barely even warm, except the blown tire; it was so hot I could barely put my hand on it. I have no explanation for why it built up so much heat, but, it cashed out.
  8. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    Under inflation is a killer. I don't know why though as air heats up expands. I can't see a tire with 50 psi getting as hot and expanding as a tire with 100.
    Maybe it does though.
    The trailer I pull has super singles and will drop 15 psi overnight. Probably different now that we're up in the 100s
    ducnut and 201 Thank this.
  9. 201
    201 Road Train Member
    12,621
    25,907
    Apr 16, 2014
    high plains colorado
    When hot, I'd run at night if I could. Recaps don't like heat, either,,I don't know, who ever thought it would be so hot in July? This happens every year, people, I read, if it wasn't for A/C, there would be no Phoenix. Not to worry, though, in a few short months, it will be back to winter pileups we haven't heard about for a spell.
    W923, stwik, mustang190 and 3 others Thank this.
  10. mustang190
    mustang190 Road Train Member
    2,871
    6,180
    Jan 18, 2011
    Florida Panhandle
    I’m trying to find me one of those “Feels Like Thermometers” they keep talking about on the news.
    Kyle G. Thanks this.
  11. buzzarddriver
    3,713
    10,979
    Feb 1, 2011
    Dallas, TX
    HaHa. No such thing. Just a number they pull out of a hat to make the weather seem more dangerous.
    The higher the humidity, the more the body responds to the heat. But, 100/deg is still 100/deg. If you stand in the shade and the wind is blowing 15mph, it doesn't feel like 100/deg.
