Heat. How how hot does everyone allow? Tire heat sensors?
Discussion in 'Experienced Truckers' Advice' started by Charlie42, Jul 23, 2023.
  1. tscottme
    tscottme Road Train Member
    Tire pressure and temp sensors are new enough lots of trucks don't have them and many drivers don't have experience driving with them. Only my last truck had the TPMS. I'm not sure I would stop driving due to the tire temp. But I haven't thought about it before. I'm looking forward to the rest of this thread to see what others say.
  3. Cat sdp
    Cat sdp . .
    21,186
    75,110
    Apr 8, 2012
    Orion's Belt
    Nitrogen is the ticket. Builds heat less then regular air…. But good luck finding it at a truck tire dealership.
    I always slowed down when it was really hot ……
    tscottme Thanks this.
  4. okiedokie
    okiedokie Road Train Member
    13,346
    103,867
    Jun 13, 2011
    PNWET
    The trucks I drove were all mechanical, no electronics. So the hotter it got the slower we drove. Those tires will get so hot you can't touch them. Run it cool.
    mtoo Thanks this.
  5. Charlie42
    Charlie42 Light Load Member
    85
    152
    Jul 1, 2021
    I-5 north and South have DOT everywhere dropping fire retardant on the new fire at Shasta. Just fyi if anyone is reading this Net conversation and might not be getting DOT info.
  6. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    What happens to "Wind Chill" during the summer?
  7. tarmadilo
    tarmadilo Road Train Member
    1,717
    4,720
    Dec 12, 2018
    I did some Googling and found several sites that said that tires don’t degrade until much hotter than they’ll get even on the hottest days.
    Example (from Bendix):
    “Most experts consider 195 degrees Fahrenheit as the “line in the sand” when it comes to tire temperature: Beyond that point, the temperature will start impacting tire life. At 250 degrees, a tire will start to lose structural strength, could begin experiencing tread reversion and the tire will begin to lose strength.”
  8. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    I've seen that tread reversion. Just last month.
  9. 4wayflashers
    4wayflashers Road Train Member
    1,066
    1,235
    Mar 14, 2014
    Woke up in Wisconsin. It was a bit chilly
  10. 4wayflashers
    1,066
    1,235
    Mar 14, 2014
    Heat index and windchill really only pertain to living things. However, there is an effect on mechanical things.
    Turn off your truck in -10 and your engine will be warm for a while. Same thing with a 40 mph wind and itll get cold much faster. Take a water pipe and run it into an unheated, drafty building. In a 40 mph wind the part thats outside will freeze before the part thats inside. Wind saps residual heat from everything.
    As for heat index on inanimate things I think it’s more about solar radiation which is different. The sun is hot, very hot.
  11. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,502
    2,592
    Jan 7, 2023
    Well, it's called a "wet bulb thermometer", the bulb is surrounded by wet fabric. You take the wet bulb temp and the dry thermometer temp, then consult a chart which gives you the "heat index" (or you can use a phone app to figure it out).
