Heat Limitations, at what point do you not run, because of heat?
Discussion in 'Experienced Truckers' Advice' started by supergreatguy, Jul 18, 2022.
  1. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,895
    Nov 26, 2020
    Is there a point at which you won’t run your truck due to heat? Is there any extra damage that be done with heat over 105?
    Here in DFW we’re gettin into the 105-110 degrees. Which is hot enough to turn a fat person skinny, a vegan into a meat eater, a sinner into a saint. All within a half a day.
  3. mitrucker
    mitrucker Road Train Member
    5,231
    9,235
    Dec 15, 2010
    Lapeer, MI
    The short answer is no. During high heat make sure the coolant is at the proper level. Keep an even closer eye on your temperature gauge. Watch your tires closely.
  4. supergreatguy
    1,030
    2,895
    Nov 26, 2020
    What would be “too high” of a outside temp to run in your opinion
  5. mitrucker
    5,231
    9,235
    Dec 15, 2010
    Lapeer, MI
    That is not even a concern. Honestly, you’re worrying about nothing.
  6. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    It's more me who has the heat limitations than the truck. Gets too hot and just strapping a load down gets me feeling like ####. I've overheated myself a few too many times.
    MOBee, okiedokie, FerrissWheel and 9 others Thank this.
  7. supergreatguy
    1,030
    2,895
    Nov 26, 2020
    point taken! Just rebuilt the AC system on my truck and wanted to ask that
    Flat Earth Trucker and mitrucker Thank this.
  8. Plantfoam
    Plantfoam Medium Load Member
    393
    1,127
    Aug 18, 2015
    DFW
    I've idled in 120f heat in Phoenix just like many others, with no problems. I had a newer truck, though.
    tscottme and supergreatguy Thank this.
  9. 062
    062 Road Train Member
    6,201
    33,404
    Oct 20, 2013
    Make sure you have plenty of water in case you breakdown in the middle of nowhere.
  10. Long FLD
    Long FLD Road Train Member
    11,807
    48,340
    Mar 4, 2015
    All I do is make sure my tires are at the correct pressure and drive slower to keep them a little cooler.
  11. welldigger00
    welldigger00 Light Load Member
    186
    1,503
    Jan 18, 2022
    These last few weeks I’ve had to bring extra clothes out on the road, after I’m done loading up, I’ve soaked my clothes all the way through like I’ve jumped in a pool. Then have to drive 500 miles. Yuck. I change all the way out before I roll
  12. supergreatguy
    1,030
    2,895
    Nov 26, 2020
    i normally keep a tote with food, 24 case water, and cooler with various drinks. I’ve been broke down with no food/water. Never again
    Lav-25, D.Tibbitt, krupa530 and 2 others Thank this.
