Heat warped hubs
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Apr 9, 2020.
  1. insanityeight
    insanityeight Light Load Member
    224
    81
    Jul 26, 2013
    birmingham al
    Just bought a new used pete 579 that dealer was using to piggy back there trucks for sale with. I guess it was doing all the stopping but on first load when you brake the truck vibrates pretty dang hard. Is there any cure for a warped drum besides replacing or having it turned?
  2. Chubby Fly
    Chubby Fly Medium Load Member
    569
    761
    Nov 25, 2019
    The only thing I can think of if you don’t want to replace or have it cut is to steel one off your buddies truck in the middle of the night while he is sleeping. Either that or just back that slack adjuster off all the way so you don’t use that bad drum. Hope this helps
    Bgarcia Thanks this.
  3. insanityeight
    224
    81
    Jul 26, 2013
    birmingham al
    Yea thats what i figured Where u parking tonight lol
  4. Chubby Fly
    569
    761
    Nov 25, 2019
    Hahaha good stuff my friend
    Bgarcia and insanityeight Thank this.
  5. Chubby Fly
    569
    761
    Nov 25, 2019
    Do you suspect your steer tire drums where the steering wheel shakes? Or is it more in your seat from the rear drums
  6. insanityeight
    224
    81
    Jul 26, 2013
    birmingham al
    Well it feels like more than one but jacked up one steer and turned wheel and it scrubs in a particular spot and not in others and the hubs look new as well as brakes but have heat cracks in all of them from what I remember
  7. Chubby Fly
    569
    761
    Nov 25, 2019
    This is a tough one. I don’t cheap out on front drums and after a months of use, they seem to develop high spots when jacked up and rotating. The rears, I buy cheap drums and they always develop little cracks and high spots but nothing noticeable when braking. Maybe yours is severe enough becuase it was a company truck where drivers don’t downshift and use jakes and do hard long stops. Why do they do this, becuase they are lazy and don’t have to pay for the brakes or replace them.
    Doealex and insanityeight Thank this.
  8. boneebone
    boneebone Road Train Member
    2,083
    1,992
    Mar 13, 2009
    I would take it back to where you bought it from and tell them to replace the drum/drums.
    Chubby Fly Thanks this.
  9. baha
    baha Road Train Member
    3,349
    1,846
    Jul 25, 2013
    ga
    The bobtail valve makes alot of the air go to ft. brakes when towing two other truck 0n top of it so taking off ft. drum that you found, and ck that it was on hub centered, then put it back on being sure that its centered on hub this time, then try it out?
  10. Chubby Fly
    569
    761
    Nov 25, 2019
    You could pull the wheels off and chew I for any rust or contaminants beetween mating surfaces. Also, I invested in a set of these pins which I think work excellent.
    A-1573
  • Draft saved Draft deleted
