Heated fuel tanks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat sdp, Nov 12, 2015.
  1. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Saw this today.....
    Artic fox coolant heated fuel tanks.......so hot return fuel and coolant both heating the tanks.
    I want some!!!!
    Winters coming.......
    sshewins and blacklabel Thank this.
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Now they need to heat the DEF tanks
  4. Nitemare13
    Nitemare13 Light Load Member
    205
    199
    Feb 24, 2014
    Hudson, Fl
    Where are going Antarctica? Winter blend or rubbing alcohol should be good enough.
  5. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Just the tundra..... :) :)
    Who ever ordered this truck knows their stuff.....
    > -20 no problem....
    sshewins, blacklabel and Nitemare13 Thank this.
  6. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Def tanks are heated
  7. 201
    201 Road Train Member
    12,061
    24,625
    Apr 16, 2014
    high plains colorado
    This is nothing new. I had a friend in the early 80's that had Arctic Fox heaters in his '79 Pete 359 tanks, and he never had a problem, Burned #2 year 'round. Very popular in Canada, hey.
  8. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    -28 is the tipping point I've found with just a block heater.
    I run TA fuel and never had a problem, even last winter With how cold it was.
  9. AModelCat
    154,609
    We used to put those in the hydraulic tanks on the new hoes we built at the dealer. Hooked up to a proheat so the engine and oil stayed warm when the units were sitting outside. Worked good.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    really don't need them with the returning fuel being hot already in the new stuff. had a set on my ole 359 with a c model cat worked great.
  11. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I've heard the new 15/16s return a lot less fuel....
