Heater blower motor slow to start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MercerDriver, Jan 14, 2016.
  1. MercerDriver
    MercerDriver Light Load Member
    69
    7
    Sep 3, 2010
    Atlanta, GA
    2003 Century. Front blower motor is slow to start.
    Thought the old one was on the way out, so purchased a new one. Seems like it struggles to get going too once I turn it on. Checked positive and negative connections at plug. Getting 12.7 volts to them. Checked signal wire. 0 volts at OFF, 5.5 volts at FULL ON.
    Why does it have problem getting going ? Any insight greatly appreciated.
  3. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    It could be a bad Blower Motor Resistor or Fan Switch, did you test either one of them.
  4. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    The way I tested the fan switch (the speed selector switch), is by the signal wire. 0 volts at OFF, 5.5 volts at #4 (full ON). Other than that, I did not test it.
  5. boneebone
    2,296
    2,367
    Mar 13, 2009
    When you use the fan switch, does the blower start working on every speed or only a few?
  6. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    Good question. I'll check it out tomorrow and report back. From what I recall, it started it almost every speed, but I'll double check.
    The other strange thing, is when it's plugged in, it's harder to spin, almost like a little resistance. It won't spin if I push the wheel. If I unplug it, it spins for quite a while before stopping.
  7. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    Seems like it starts in every speed, but , as I stated before, there's a slight hesitation before it starts to spin. When it does start, it seems it's slow to get going.
    One other thing I noticed, is when the blower motor is connected, it won't turn freely, like there's resistance of some sort. When unplugged, the wheel can spin for several seconds.
  8. boneebone
    2,296
    2,367
    Mar 13, 2009
    When the blower fan is on, is the speed normal according to its numbered speed position on the fan switch, or is it the same speed in every position?
  9. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    The motor speed changes according to the # on the control panel
  10. boneebone
    2,296
    2,367
    Mar 13, 2009
    I would look into replacing the Blower Motor Resistor. It seems like your Fan Speed Switch is working, but the Blower Resistor is making the fan start up slowly and not letting it run at the speed it should be, especially since you already installed a new Blower Motor, so we know it's not that.
