Heater core
Discussion in 'Questions From New Drivers' started by carwreck, Nov 25, 2010.
  1. carwreck
    carwreck Light Load Member
    155
    46
    Feb 11, 2010
    Chicago, IL
    My heater core took a dump in my 2000 International 9200. Any ideas as to where I might find it to replace it? would it be buried under the dash like in cars?
    Happy turkey day... and thanks!
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Follow your heater hoses. Will have to be a inlet and a outlet.
  4. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    look under your passenger seat
  5. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    It's easy to replace. As said, it's under the passenger seat.
  6. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    if it is the same as other ihc's--you will have to unbolt the panel that holds the seat down--and seat belt i believe--then the whole works lift off and it is underneath--its not bad to do--just different--and a filter under the access panel on the right of pedastel
    just to make sure--like tarps said follow the hoses---no need to drain rad--just pinch off the hoses
  7. lego1970
    lego1970 Medium Load Member
    504
    165
    Oct 10, 2008
    Blue Springs, Missouri
    As mentioned under seat. I drove an international that never would put out heat except when you were driving at high rpms and even then it wouldn't always work. They replaced the water pump, heater core, lines, filters, checked for cracked head or blown head gasket, etc, etc, and a couple more etc's. Neither they nor I ever did figure what the caused it but somehow it would get an air bubble in there or something along that line and therefore couldn't transfer the heat. Made a long day even longer. Nothing worse then tarping a load down or putting on chains in the dead of winter then getting inside an ice cold truck not knowing if you would have any heat or not.
  8. carwreck
    155
    46
    Feb 11, 2010
    Chicago, IL
    I hope replacing the heater core would fix this heat problem. It doesn't give any warm air.. it's torturous to drive in this could weather!!!
    thanks fellas.. will check tomorrow if I can figure this out..
    any ideas or input is much appreciated :)
