Hello! Need help please. The yellow knob is not popping out.
Discussion in 'Ask An Owner Operator' started by Dok2304, Jul 6, 2024.
  1. Dok2304
    Dok2304 Light Load Member
    185
    49
    Sep 19, 2013
    Hello, I had an inspection, and they notice the brake valve , yellow knob is doesn’t pop out when 40-20 psi. It doesn’t pop out not even when it’s 10psi.
    I have an Freightliner Columbia glider. Can anyone help me with some info, much appreciated, and thanks in advance.
    Flat Earth Trucker and austinmike Thank this.
  3. kwswan
    kwswan Road Train Member
    1,986
    10,721
    Jul 26, 2009
    mcminnville,tn.
    Could be the dash valve or the tractor protection valve.
    Flat Earth Trucker and Dok2304 Thank this.
  4. Dok2304
    185
    49
    Sep 19, 2013
    So I’ve read about the tractor protection valve, and then I’ve read about the sensors, electric air sensors that are inside dash. They’re bunch of them, and very truck is different, and when you go to dealer they can’t say what you need unless you remove the sensor
  5. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,941
    Oct 31, 2023
    Put a new dash valve in.
    beastr123, Deere hunter and Dok2304 Thank this.
  6. Cattleman84
    Cattleman84 Road Train Member
    9,992
    71,278
    Nov 1, 2017
    The Sticks, Idaho
    That valve doesnt require any electronics to function properly so odds are its the tractor protection valve or the dash valve itself. Neither are very expensive and both are easy to replace.
  7. AModelCat
    161,291
    Tossing darts at the wall based on a symptom described over the internet I will also go with the dash valve being defective.
  8. Dok2304
    185
    49
    Sep 19, 2013
    Tractor protection valve, where is located? Thx. I’ve replaced couple of dash valve, myself, before. The tractor protection valve is $70, the red&yellow knob valve is $260
  9. Cdemars316
    Cdemars316 Heavy Load Member
    813
    4,897
    Nov 10, 2018
    Not to be an ###, but that should be part of your pre trip, the dash valve can also be taken apart and cleaned before you just go ahead and replace the whole thing
  10. Dok2304
    185
    49
    Sep 19, 2013
    The red one is popping out, but the yellow doesn’t. It’s a rebuilt kit, with o ring silicone gaskets and grease, but freightliner like to sell the valve, instead of the rebuilt kit that cost no more than $20-$30. I don’t believe cleaning it, will do any good. I’ve rebuilt it 2 times, but it’s a pain to remember or to find the exact part number for that kit, and if you don’t ask for it, they don’t wanna look for it, for the part number anymore. You have the know the part number to get it.
    beastr123 Thanks this.
  11. Dok2304
    185
    49
    Sep 19, 2013
