Help. 04 Freightliner. What is this and how to fix it?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JRut, Jun 6, 2021.
  1. JRut
    JRut Light Load Member
    185
    56
    Jul 11, 2012
    Texas
    Sorry for the dumb post. Got a good deal on this truck but it needs a few minor things. Figured I would try to fix it all myself. This is my first truck as I transition from company driver to owner op and need a little help. I've searched and searched and cannot find anything on this. What is this thing pictured? It has a couple of lines broken off of it that are slowly dripping what looks like oil. How to fix? Don't even know the name of this to look up info on how to fix it. Thanks in advance
  3. AModelCat
    161,615
    That there is not OEM Freightliner. That is an add-on automatic greaser.
    Its a Groeneveld product.
  4. JRut
    185
    56
    Jul 11, 2012
    Texas
    Thanks for the info. Now I can at least look up to see if I can find parts for it. Do I just fill that reservoir with grease? It's bone dry but those lines coming off of it are dripping oil
  5. Lazer
    Lazer Road Train Member
    1,830
    2,939
    Jan 22, 2017
    That is a constant grease dispenser. There should be small lines from it running to most of the grease fittings on the truck. Every ‘X’ number of minutes of run time, it injects grease into the fittings.
    Worked for company that had them on some units, great when it worked, pain when it didn’t. Took a very thin grease, almost pourable.
  6. JRut
    185
    56
    Jul 11, 2012
    Texas
    Thanks. That would explain the oil looking stuff dripping from the broken lines.. Hopefully it works. I'll try to get all the connections fixed and fill it up with the proper grease and go from there.
  7. JRut
    185
    56
    Jul 11, 2012
    Texas
    I'm just going to remove it completely. I put some new connections on and got the hoses back where they should be and it doesn't work. I'll just have to grease it manually from here on out.
  8. AModelCat
    161,615
    Probably better in the long run IMO. Gets you under the truck more often where you can check everything over regularly.
    JRut Thanks this.
