HELP!!! '13 Volvo D13 shakes & power loss at 1,600 RPM
Discussion in 'Ask An Owner Operator' started by MaxzRig, Jun 3, 2018.
Page 4 of 7
@MaxzRig you need to get a proper diagnostic done. You may or may not be looking at a 6pack of cups/injectors. Check out the Volvo subsection there is plenty of Information there to help.
Here are the symptom of bad cups.
RPM fluter 1200 to 1400 clears up at 1500 plus.
Loss of power
Longer cranking time. (Loss of prime)
Loss of MPG
In extreme cases shoot gets into the water separator.MaxzRig Thanks this. -
Why are you running it to 1700? I had a 13 d13 in a 780 and never needed anything over 15 and that was rare?
Also... the injector issues were Long solved by 13. If you DRAIN YOUR WATER FILTER every day you should have no issues. Mine had none and 3 friends the same. The guy I sold it to called me 6 months later.. it needed injectors... I asked if he was draining the water filter he said no..never.
Maintenance folks.. maintenance. -
shogun Thanks this.
What? @Elroythekid in the 5 years of owning my 2010 not once have I heard of what you claim. Cup failures still happen even with updated cups.
I cannot get my head around draining anything somehow prevents cup failures.Last edited: Jun 4, 2018
So the water fuel separator somehow prevents cup failures? WTF who knew?
@KB3MMX !!!!!!!Last edited: Jun 4, 2018
NOBODY I know with a d13 after 12 has had injector issues? I was told the cup issues were taken care of.
Page 4 of 7
