HELP!!! '13 Volvo D13 shakes & power loss at 1,600 RPM
Discussion in 'Ask An Owner Operator' started by MaxzRig, Jun 3, 2018.
  1. monsterfacetrucking
    monsterfacetrucking Bobtail Member
    4
    Jul 31, 2018
    Hey, did you ever get your issue resolved? We also have a 2012 D13 Volvo bought 6 months ago and are having identical problems. Was it the injectors.cups or something different? We have replaced about 8 sensors, both fuel filters and few other small things on the EGR and turbo, mostly sensors that the computer comes up with and still have engine derate in 7th and 8th gear under load, shaking and loss of power. We are $2,500 into this and are running out of time, money and options!!! PLEASE HELP!
  3. Macogapi
    Macogapi Bobtail Member
    Has anyone solved this problem? Have a 2007 d16 doing the same thing
  4. Greamreaper
    Greamreaper Bobtail Member
    31
    7
    Feb 17, 2018
    I had a 2009 ishift at my rookie months. Same problems, shaking which goes away after letting of the gas, climbed i17 AZ at 20mph or less. 2 bad injectors. The boss was greedy, took him ..while to replace and problem gone.
  5. MaxzRig
    MaxzRig Light Load Member
    60
    26
    Feb 20, 2010
    LAS VEGAS, NV
    Well, just a follow up to anyone who has read this post. I originally had the problem diagnosed @ a Volvo dealer. "Injectors", pure & simple. They said VOLVO TRUCKS around this year, were famous for injector problems. Though I only had "one bad one". They @ Volvo were advised to CHANGE THEM ALL OUT, because the others would or could eventually fail. They REALLY had to CONVINCE the cheap ### warantee company (didn't want to pay it), but finally did.
    Since then (6 mos. later), I've had water in my tank (fuel cap left off-oops) and after a few fuel filters changed & a tow... They diagnosed the "NEW" problem as injectors again. They were under warantee, so "NO CHARGE" to me for new set!!!
    About that same time, I'm still seeing black particals in my fuel filter. Having to change it regulaly. At first I thought it to be the fuel. But after research, found it to be 'algae' from the bio fuel mix. They have stuff that you can buy (don't remember the name), that will clean it out... BEWARE of how you use this stuff, I think I got heavy handed & possibly another reason for an unexpected trip to the shop. I think it cleaned out too much too fast & plugged up something in the system!!!
    Now after TWO SETS OF INJECTOR REPLACEMENTS in under 12 mos. I will be paying close attention to the full chain of fuel to motor, to filter maintenance requirements! LoL.
    PS; to all you 'experienced maintenance & knowledgable' fellows. I thank you all for your helpful comments & added notes to this post. Again, I am a new truck owner, now about a year and trying to get past this giant hic up... I appreciate all yalls help.
    86scotty Thanks this.
  6. Nskpool
    Nskpool Bobtail Member
    7
    4
    Oct 30, 2018
    i am having same issue with 2009 volvo vnl 9th gear dont go pass 1500 rpm same for 10th if i trying to go pass 1500 it shakes. gonna clean 7th injector to see if any diffrence it makes i m not getting regen bcuz i had truck parked for a month..lets see whats it turns out to be any suggestion from ya'll brothers will be appreciate it.
    losing power at 9th & 10th gear soon it reach 9th gear its not going pass 1500 rpm tomo i am
  7. Driver0000
    Driver0000 Medium Load Member
    304
    320
    Jun 26, 2016
    If the truck was governed, it will have rev limits set that describe your problem. You have to remove the MPH governor and the rev limiter or you will have loss of power when the engine hits the Volvo sweet spot. It is fixed with an ECM change and it takes 10 minutes and should not cost more than $50- if your mechanic is cool.
    Volvo will try to sell you a new engine and everything short of the quick fix, so beware.
    2012 and earlier D13's will have injector cup issues that manifest in hard starts because air is getting in the fuel line. You can double check it by removing the return line on a tank and placing it in a clear container. If it bubbles, you have a failure in at least one cup.
    Replacement parts (6 pack) should not be more than $2700 or so. Labor is about 10 hours by the Volvo book. Dealerships will mark up parts so negotiate.
    Note: When my cups failed, I had zero loss of power when driving the truck.
  8. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Leaking Cups ...and usually they damage injectors from soot contaminated combustion gasses that enter the fuel supply in the head. (Black fuel filters)
    Increased loads usually exacerbate the air leak problem into the cup interior. (Higher gears, heavy loads, winds, pulls, etc)
  9. CaliTrukBiz
    CaliTrukBiz Bobtail Member
    I know this is an old post but did you ever find out what the shaking was? Read on another blog it's the u-joints. WE've done all the above everyone mentioned in response. U-joints don't come up in computer tests and are between the drive lines. Also know matter what truck you get, they all need work. Some more than others.
  10. Schöne
    Schöne Bobtail Member
    47
    20
    Feb 23, 2019
    What if it struggles to go a
    What to do if it won't shift at 1500 like mine? If I don't shift at 1600 it struggles to go and almost stalls
  11. Schöne
    47
    20
    Feb 23, 2019
    Mine will stall if I don't shift over 1500
