HELP! 14.0 Liter Detroit using oil (EGR)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by overdalimit, Aug 5, 2010.
  1. JOHN6006
    JOHN6006 Bobtail Member
    18
    16
    Dec 31, 2012
    Austin Tx
    Don't feel bad , I have a 2006 dump with 321,000 miles on it and have been using a gallon a day of oil for over a year ,
  3. little cat 500
    2,048
    1,094
    Jan 17, 2010
    Abbottstown PA
    i don't think mine has enoughpower to burn oil lol
  4. Dok2304
    Dok2304 Light Load Member
    185
    49
    Sep 19, 2013
    that sound is the turbo< I have same thing, since I installed the egr delete resistors. I think maybe turbo actuator need adjusted??
    rob27230 Thanks this.
  5. BigYellower
    BigYellower Bobtail Member
    30
    Mar 18, 2012
    Sammamish wa
    FYI: to all those whom own a DD series 60 EGR engine 03-07 . The system has to be maintained.
    For the EGR /turbo to work right. You have to tear down systems and clean it 4 times a year. EGR Cooler does clog . If EGR is acting up is do to clogged EGR cooler.. The clog will drown the the intake manifold with soot.. U have to take manifold off and clean it and put new sensors in and put back on..
    also if possible stay away from reman turbos. They are junk. You can get a new Garrett for the same price as a reman. Check out pitpower.com for exhaust manifolds, turbo blankets, exhaust wrap, and better exhaust muffler.. Be aware the all the accessories attached to the engine block relay on eachother..
  6. rob27230
    rob27230 Bobtail Member
    9oo
  7. killer120
    killer120 Light Load Member
    70
    43
    Jul 1, 2013
    I'm a diesel mechanic up by Portland Oregon, sorry I haven't really ready the whole thing, just a sentence or two but it sounds a lot like you have a chipped or badly scratched cylinder liner or broken piston ring, would leak oil into and burn it out fairly quickly, may not see it at load because of the boost pressure blowing against it and thinning the smoke out but at idle may see a very slight white smoke with a little black in it and may smell a slight oil burning smell, unless the exhaust housing seal broke on the turbo, but I doubt it, looks like it might be time for an inframe, if you wanna save a little money, pull off the valve covers, jake brakes, cylinder head, oil pan, and just unbolt the rod caps and slide out each piston and check for split rings or marked cylinder liners, if so, get a liner puller and take in a piston in good shape with a liner in good shape and have freightliner measure it with a dial caliper and give you a new one to replace the bad one, install the new liner, lube the liner and piston, slide it in with a compression sleeve and put the cylinder head, oil pan, jakes and valve covers back on and it will take you a full day or two to do but even with buying the tools will save you so much, a basic inframe is around 7k from a private place and upwards of 20-25k from a dealer, just my advice, may get you another 200k miles or more
  8. rob27230
  9. Highrollers
    Highrollers Bobtail Member
    41
    26
    Jun 8, 2018
    Im using a gallon a day. Detroit 14l . Trying to get $$ together quick. No oil leaks either none in air tanks. A mechanic told me it was rings definitely. The only problem is im an owner operator i aint got no money lol.
  10. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    You need overhaul asap
    Highrollers Thanks this.
  11. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,293
    Sep 12, 2017
    Plymouth MI
    You cannot just replace a liner and piston... In frame it properly with OEM parts and be darn sure you are in a competent shop. Been there and done that.
