Help. 2004 Pete 379 Will not start. Not turning over
Discussion in 'Peterbilt Forum' started by walshie38, Mar 10, 2012.
  1. walshie38
    walshie38 Bobtail Member
    14
    Mar 10, 2012
    Hi there.
    I am going to try and give as much info as possible, Whatever you need for info i will Reply back as soon as possible with it
    2004 Pete
    475 Cat (Not sure if its aCert or BXS) ( not even sure if that is right )
    Drove it Last night to hook up a trailer and when driver went to truck this morning it would not start . Wound not even turn over .
    So we hooked up jumper cables and nothing just turn the key and it cranks for about 1.2 seconds .
    OK so tried putting charger on it . Nothing not even a change..
    So i tried boosting it from my other Pete and again nothing
    The batter gauge on the inside says 16 before turning the key and 14 after.
    There is no check engine codes at all (55)
    I really dont understand what it could be as it fired up GREAT last night hooked up trailer and then nothing ..
    Whats been suggested
    Clean Battery Posts
    Look for loose grounds around started
    Battery are shot
    Starter or cycloid could be shot too
    Thank you
  3. LandShark
    LandShark Road Train Member
    1,525
    1,064
    Nov 22, 2008
    Riverdale, Ga
    I had a starting issue with my old Pete with a 475 cat. My mechanic made me a special tool too start it. He told me I had an Arkansas flywheel. It had no teeth. So I would have to manually turn the crank like an old modle T then it would start.
  4. JRP
    JRP Light Load Member
    99
    17
    Dec 5, 2011
    Halifax, NS.
    Youre not getting fuel. Is there fuel in it?
  5. walshie38
    14
    Mar 10, 2012
    Yeah there is lots of fuel.
    It doesn't even get to that point. its as if the battery's are dead and it wont turn over .
    With hood open when you turn key the fan will move about 1 inch then it will not turn over anymore
    tnx
  6. walshie38
    14
    Mar 10, 2012
    Wow thats gotta suck ah . Pretty sure that's not my problem . Thank`s for your input . LOL:biggrin_2559:
  7. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Check power at starter while cranking with test light at the small stud with wire going to it make sure your not losing power to starter while cranking then check starter relay on left side of firewall also check all connections at ign switch and all grounds ant positive cables at starter and batterys you might also load test the battaries might have a bad battery
  8. oc83baker
    oc83baker Medium Load Member
    410
    127
    Jan 18, 2011
    all 48
    Try sparying starter fluid in the intake
  9. oc83baker
    410
    127
    Jan 18, 2011
    all 48
    try puttin 4 new batteries in there, you can alway take them back if it don't start
  10. oc83baker
    410
    127
    Jan 18, 2011
    all 48
    I had a starting problem the batteries were shot and I was just running off the alternater, kill th alternater, I replace the alternater truck run fine for 1 week (still didn't know batteries were dead) then truck die on he scale at loves, I try jumping it wouldn't start, try charging it wouldn't charge, so I got 4 batteries from loves it start right up, haven't had a problem since.
  11. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Sounds like a poor connection at the starter since it works for an instant until the poor connection heats up and goes open circuit. The L shaped metal link that connects solenoid power to starter motor is a common failure, as well as b+ and b- connections. The poor connection is often good at hiding. You have to put a wrench on it to find it as rust and corrosion can be hidden and insulating the intended connection. Sometimes if you watch it in darkness while attempting to crank the poor connection will show arching or turn red hot. Good Luck!
