HELP???? 6nz fuel filter base prob
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jaysolomon, Sep 13, 2012.
  1. jaysolomon
    jaysolomon Light Load Member
    78
    7
    Sep 17, 2010
    Hello,
    I have a 6nz CAT and I was servicing it this evening and noticed when I pulled the bleeder valve out of the fuel filter base (to prime it) that their was a lot of thread shavings in it. So I tried to screw (it did fine) the bleeder back in and tighten it up and it wont get "snug".
    My question is, does anyone have a clue of how much a base is and which one do I buy as I have seen reports on here talking about them using a different number?
    Thanks in advance
  3. droy
    droy Heavy Load Member
    828
    159
    Jun 11, 2008
    Iowa, LA
    Is this the secondary fuel filter base, the one usually mounted behind the air compressor? Don't know how expensive, but if you want to replace it, I would try a salvage yard.
    Same thing happened to me on my '96 3406E in a W9, on a Sunday. I took the base off, then CAREFULLY ( base is aluminum, thin aluminum!) drilled and tapped the hole to 1/4" pipe. ( doing this requires a "bottoming tap"; I simply made one by grinding a tapered tap.) After tapping it to 1/4" pipe threads, I screwed in a 1/4" male x 1/8" female brass bushing, then used a 1/8" hex plug to bleed the air.
    If you go this route:
    (1) Be VERY CAREFUL drilling and tapping; go too far, and you can bust the plate under the bleeder screw.
    (2) Be sure to blow all the shavings out before re assembling.
    (3) ALWAYS hold backup on the 1/4" bushing when screwing/unscrewing the 1/8" plug- very easy to strip the aluminum, as you have already found out.
    It's not really a hard job, and it lasted me a couple of years til I sold the truck.
    As for as installing a different base, I think they were talking about the primary (fuel/water separator), at least the discussions I was involved in were referring to installing the same base used on the 35 series engines (i.e. the 3512), for more fuel flow. On the road now, and don't remember the part #, it was $200.00+, but it wouldn't help you if it is the bleeder screw on the secondary ff base.
    Good Luck!
  4. jaysolomon
    78
    7
    Sep 17, 2010
    Thanks
    Yes I am talking about the secondary ff base and sorry I forgot that vital info.
    I called the local CAT dealer and they have one for $173 bare. I got to transfer check valves etc over to new one which is not a big deal.
    Another Q if I may:
    Do y'all run the CAT 1r0749 filter or something else?
  5. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    The 0R-0749 fuel filter is the filter to use on the secondary base. I use CAT part # 256-8753 as the primary fuel/water separator filter as it is larger and less restrictive
  6. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Just get rid of it, install a Davco 382 and never look back. You can get 2, 5, 7 and 10 micron filters or higher. I don't know why anyone would want a spin on filter.
  7. W900KW
    W900KW Light Load Member
    52
    14
    Jan 18, 2010
    south dakota
    if just the pump is bad you can replace it or block it off, no need for a whole new base
  8. jaysolomon
    78
    7
    Sep 17, 2010
    My primary is the "clean out" type screen filter. I assume you meant 1R-0749 not 0R-0749
  9. jaysolomon
    78
    7
    Sep 17, 2010
    Thebpump wasn't bad, the threads in the filter base that the bleeder valve screws into are stripped.
