help. a/c on, engine fan wont shut off
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Nov 4, 2010.
  1. rollin coal
    rollin coal Road Train Member
    13,089
    25,928
    Mar 29, 2008
    TN
    Whenever I turn the a/c on or use the defrost my engine fan comes on and wont go back off even if i turn the a/c off. A mechanic told me where to unplug the a/c fan harness from a schrader valved sensor then put a jumper wire in the harness. I did and it worked. This just happened last night. I had barely enough time to grab a new sensor at a kenworth dealer slap it on, and make my delivery appointment. So new sensor on there and i have the same problem fan will not go off. So is that brand new sensor defective or is my trouble something else? Rite now i have the harness jumpered so the fan will stay off. Will i be ok to roll like that a few days? I can turn the fan on/offf manually i guess if i idle with ac on just flip the fan on??
  3. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    does it not go off EVER? usually the computer has a timed delay programed into it. how long that delay is depends on how it was set up new. if it's a used truck different companies set them differently. So even though you turn it off there may be a few minutes before it will go off.
    Also, generally in most newer trucks the solinoid will supply air to the fan to turn it off and exhaust air from it to turn it on. That way if the system fails the fan stays on. If you run it with the fan off you will overheat it if you get in stop and go traffic or climbing a hill. You would be better off to leave it on. then it's just annoying but at least you won't blow your motor
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Edited: MedicineMan beat me to it. Listen to what he says.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    seems to me bad sensor... but to be sure use diagnostic software to monitor sensors and check for delay programming?
    What engine do you have? ISX? Cat? DD? What year is the truck?
  6. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    I did the exact same thing, only on my International, replaced the sensor and the fan still stayed on for forever after I shut the a/c off. I don't know much about a/c, but it turned out that the system was overcharged, and the sensor kept the fan on until the pressure went back down. I had the system drained, replaced the dryer, and had it charged back up and that solved it. (I replaced the dryer because it looked like it was the original one.)
  7. rollin coal
    13,089
    25,928
    Mar 29, 2008
    TN
    Thanks for your input guys! I should have posted more info but it's a pain posting when I have to do it from my cell phone like I did yesterday. Ok here's some more info..
    It's a C15 bridge motor unbridged 550hp1850tq 6NZ flash 2003 T600. First off I watc h my gauges like a hawk and even when it was stock MBN ecm always turned the engine fan on manually when the water temps hit 201* on the digital Cat driver information display and pull it bac k down to 188* where I shut it off. The highest I ever see it go even with the fan on is 204* the factory has the fan set up to come on automatically at 217* which I always thought was way too high and late... So don't worry I'm not going to overheat my motor watch the gauges religiously and use the fan as needed.... .....I didnt just graduate from truck driving school lol...
    The a/c system was completely redone this past spring and works fine. New compressor, new drier, two new expansion valves and filled with freon to factory specs. Worked fine all summer causing no problems.
    My engine fan automatically comes on to pull air through the a/c condensor when I'm parked idling or when I'm slowly driving through a parking lot in 2nd or 3rd gear. When I go down an on ramp and pick up speed to 65-70mph it will stay on for a couple of minutes then goes off and never comes back on again as long as I'm at highway speeds. I say "never" ocassionally on a hot summer day pulling a mountain grade it will automatically come on but again that is very rare and my engine water temps never go over 201-204* so you might as well say it never comes on.
    This all happened to me wednesday night going south on I-81 in VA. It was nighttime and the outside ambient temp was about 50*. It was raining. I'm pulling a hill loaded heavy and my water temp was at 192* ( my motor normally runs 188-192* all the time) with the defrost on (the a/c is on when defrost is selected) and my fan comes on. It ran continuously and would not stop even after going to vent with the a/c off for about 50 miles. I stop and shut her down to grab a burger at the 101 exit and check things over. I get back in the truck and make sure the a/c is off before I crank it back up. It starts and the fan is not running. I go about 10 miles down the road and turn the deforst on to de-fog my windshield and almost immediately the fan comes on and again will not shut off for anything. I drive on down to knoxville with the fan on the whole time and stop at MHC Kenworth...
    A mechanic there told me to unplug the a/c harness from the switch fan override sensor and to stick a paperclip in the harness to jumper it and see if that made the fan go off. Well, it worked... So the sensor was bad and I bought a new one and swapped it out right there in the parking lot. I was pressed for time to make mny delivery that morning and left but it was still doing the same thing as if changing the sensors out helped nothing..... So when I get to my delivery I put the jumper paperclip back in there so the fan would stay off ( I got 4.8mpg!!! because the fan was running) and stopped at nashville later that night to get ANOTHER $45 fan switch sensor... I'm going to put that on in the morning and HOPE it fixes it if not I dont know what to do...
    I was really wondering if it would damage my a/c system to run with that jumpered wire for a few days or weeks if needed??? If I'm sitting around idling and the fan is not manually switched on will it damage my a/c system? I can turn it on manually if so... I just hope this second brand new sensor fixes it and the first one was faultly... It was made in mexico... Only concerned about POSSIBLYdamaging the a/c not worried at all about overheating the motor trust me that AINT going to happen the way I watch gauges and use the fan....
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    problem you describe is not so simple. to determine a sourse you need Cat ET software and laptop in your truck to find the faulty sensor.
    I'm not sure you have new sensor bad againe!
    well, the other good idea - save engine parameters to file and post this file there.
    the bad news, all Cat ECMs are locked with password and it is not so easy to change anything!
  9. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I had the same problem last summer. Turned out to be a bad connection at one of the plugs by that sensor. This mag chloride they use one the roads now eats elsectrical. I cut the plug out and wired it directly
  10. rollin coal
    13,089
    25,928
    Mar 29, 2008
    TN
    I replaced the harness last spring when we re-did the whole a/c system but anyways I was worried over nothing. Put another new $45 fan switch sensor in it today and the problem is solved. So that first new sensor was faulty. That's made in Mexico quality for you... Thanks for all your input drivers maybe this thread will help somebody else out some day...
  11. josh.c
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    Good job on not just assuming that a new part can't be bad. You gonna try to get MHC to take the bad one back?
    I wonder if anyone sells a gauge that can read that sensor-it'd be really interesting to me to see what kind of pressures the a/c is seeing in different situations.
