Help...A/C Problem
Discussion in 'International Forum' started by joe9246, May 3, 2012.
  1. joe9246
    joe9246 Bobtail Member
    23
    detroit, mi
    I have a 2005 International 9400i with a Cat c13 acert . My a/C is fading in and out warm then cold...any idea what could be causing this to happen?
  3. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    Could be freezing up then thawing out, back and forth. Have you had any recent AC work done?
  4. joe9246
    23
    detroit, mi
    No work done on it and it was working fine yesterday. It switches back and forth from warm to cold every 10-15 seconds.
  5. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Turn off your heater hose valves and see if this stops it. Could be air mixture door problems. Could also be low on refrigerant, causing the compressor to cycle off when the suction pressure drops too low.
  6. joe9246
    23
    detroit, mi
    Thanks...I'll look into it.
  7. bender
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    Changing every 10-15 seconds does sound like a blend door control problem.
  8. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Or its simply a little low on freon. Is the AC compressor kicking in and out every few seconds?
  9. pcdoc2001
    pcdoc2001 Bobtail Member
    6
    Westmoreland, Tn
    The compressor will cycle if the system gets too cold and freezes up the evaporator but the fan should still be blowing fairly cold air till the compressor starts up again. One sure way to see if the system is full of 134a is to touch the high pressure a/c line that leads from the compressor to the condesor that is in front of the radiator. The temperature of the 134a increases as pressure increases so this line should be hot to the touch. Hot enough that you want to be careful when you touch it with the a/c running. When this line gets hot the pressure in the system rises so the condensor or radiator fan comes on to cool the a/c condensor down. It is controlled by the ecm so that it doesn't come on past 40-45 mph, (the fan can't help at this speed). If the line is not hot you are low on 134a so you have a leak, a clog or a weak compressor, (it's barely ever the weak compressor, and clogs generally make the line even hotter). If the line is hot and the compressor keeps shutting off with the fan not running then it is overpressurizing and you will need to look into this quickly. I hope this helps. By the way I'm a Porsche tech not an International tech but being from Florida I have repaired over 75,000 a/c systems and using your hands to feel the temperature of the lines is the fastest way to diagnose. I hope this helps. Joe
  10. joe9246
    23
    detroit, mi
    Well I turned off the heater hose valves and it is working fine now. Thanks pcdoc for the info. Thanks for everyones help.
  11. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Your blend door is still faulty. They warp and become miss shaped over the course of time and allow heat from the heater core to leak through. Not really a big deal until it becomes stuck. Shutting off the taps in the Summer time may be all you have to do, but just be aware that door might cause problems down the road.
