help a c15 intake rocker arms keep breaking
Discussion in 'Freightliner Forum' started by lashbrooksl, Oct 27, 2012.
  1. lashbrooksl
    lashbrooksl Bobtail Member
    I would appreciate any help with an explanation as to why the intake rocker arms keep breaking. I replace one and then a different one breaks and so on.
  3. Chain Drive
    Chain Drive Medium Load Member
    436
    113
    Nov 28, 2008
    Nova Scotia,Canada
    pulling up around 1700 1800 and letting off the fuel allowing the jake to come on,
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Have you had the head rebuilt or the cam changed? It could be a pushrod/valve clearance issue on the intake side.
    Another thing is the valve guides could be sticky or oval shaped making the rocker hit off center.
    Any other signs of damage?
  5. lashbrooksl
    I replaced the head from a different engine. It will start up and run good for a few minutes then the intake rocker arms will start to break. what is causing this. There is no other damage.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    replace valve, valve liner and valve SPRING, yep, weak valve spring is the problem at high engine speed
  7. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    replace the all with new ones. a common c15 issue. i think they even have a recall on them....replace the studs and all.
