A search for what I would have been looking for. Start at $35,000. I offered them $30,000 for mine and they took it. I should say, I bought my Century with 708K miles on it too. http://www.truckpaper.com/list/list...=contains&bcatid=27&Pref=0&scf=true&HDROR=asc
That dealer sells all kinds of trucks, their about 2 hours away from me. It said in the description that it does have a Tri-Pack APU so that's a major plus. I say with that many miles, if you do proper maintaince on a regular schedule it'll last for another 500,000 miles maybe even more. If you run hard and a lot in a week I'd get it serviced right when you get home. Where it'll have fresh oil to run the next time you're out. The very first thing I would do is get the radiator flushed and change the transmission fluid. Those are the most I unserviced things on a vehicle. Good luck!
Before changing any fluids I'd pull samples from each. Then you'll have a real idea of whats going on.
I no details other than what's said in the description. I personally don't wanna email or call them. They'll start calling and harassing me trying to get me on the lot where they can sell me something.
I hear ya. I found my truck that way and I just knew it was going to be mine. It even had my name on the posting. The salesman who listed it has the same name as me. 2 months later I was driving it home from WA to MN.
if do want to email for info, might want to setup a temp account u would not keep. no real names etc.. that info on the century class was real eye opener, lighter and shorter. picking a freight shaker over kenworth? just goes to show you what the reality in comparisons bring out. brand specific trucks, i get that as seen where just ordering a simple rubber gasket could be problematic
I have wind noise on the CB antenna's. I am actually considering relocating them to the back of the cab. Will see how that goes. For the doors, I made a couple of polar fleece blankets that hang from the wing window and door lock to block the draft from my leg. I found some of those 50X60" polar fleece blankets at Menards for $1,97. Put in a couple of grommets in the right place. Instant hangers. I do want to replace both of the seats and just recently put one of the old twin mattresses from the kids in the truck. I figured it was the old mattress that was stinking the thing up. And it was. Repairs on my truck I've done. Kingpins and tires, $2600 Exhaust Man gasket $1000 APU work, $1000 (5 broken wires and a bad power switch, bad motor mounts and idler pulley) Bunk heater (just replaced that this week) $828 ECM programmed $XXXX. That's between me and Rebel but worth every penny you will spend on it. Two new recaps on the trailer, $360. Pair of rubber hoses for the intake between the Turbo and CAC $60 with clamps, total of $80. re-shimmed the power divider $100. Air Dryer Service pack (new Desicant filter and purge valve) $160. Still need to do. Batteries (2 marginal, one not marginal, not good, 1 good) $800 for yellow top Optima's. Planning on drive tires come summer/fall $4800. Landing gear for trailer ($400) Rear trailer doors ($540) I seem to be replacing my wiper blades every 3-4 months now. Enough so, I am looking to just by them by the case. (it's a pet peeve of mine)
