Help! Best Truck/engine for $30000??????
Discussion in 'Ask An Owner Operator' started by buddyvuk, Jan 6, 2013.
  1. 25(2)+2
    18,756
    45,804
    Sep 18, 2006
    the road less travelled
    Overhead is important and gets neglected. I had a used DPF Series 60 14, had been a Lessors truck. At just over 500K, the rocker arm assembly broke, it still ran, but not very well.
    Had it fixed at Oak Creek, they ran the overhead because they had to when installing new, and the truck sounded like a new truck, and got better mileage.
    Lessors traded them in with under 400K, the lease company bought 20 of them to lease out. They are getting rid of them now, they had more failures like that.
    The truck had a lumpy idle, had it reflashed at Dubuque when it was there to fix some other issues, and after that, it pulled and lugged better than any ISX I had driven, including the early, non EGR one. It always had a smooth idle after that, too.
    blacklabel Thanks this.
  3. buddyvuk
    buddyvuk Medium Load Member
    337
    66
    Jan 6, 2013
    portland oregon
  4. timetotruck
    timetotruck Bobtail Member
    26
    16
    Jan 2, 2013
    WI
    Question; how are front and rear axle weights determined. Example 12,000 steers, 40,000 rear tandems. I see rated at 10,000 steers and 38,000 rear tandems.
  5. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    that's the rated "load capacity".
    You aren't going to want 34,000 lb axles for running off-road belly or side-dump on a construction site.
  6. timetotruck
    26
    16
    Jan 2, 2013
    WI
    How is that rating determined? What is the criteria used to determine what the rating is?
  7. Iron-Man
    Iron-Man Light Load Member
    58
    97
    Apr 14, 2016
    Oklahoma
    ^BUMP^
    I'd like to know the answer to that question as well. What's the difference also in 38,000lb rear axle and 40,000lb?
    I'm looking at buying a truck this week and many of the trucks I've looked at have differing weights on the rear axle. I'm wanting to do flatbed work if that makes a difference.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    30 K?
    As much horse you can get away with. It will allow you less hourly fuel burn fighting the Winds out west and long mountain grades. 500 horse and up. 13 speed minimum.
    Regarding truck cabs and sleepers. Get as much volume you can. Our Century for two people was about as good as it got in our time. Short enough to get into some places but big enough to live in waiting two days for freaking Americold to finish blast of produce without killing one another. But in serious winter cold if you do not have side skirts between drives and steers, you gonna get a touch cold.
    Avoid the emissions as much as you can. California is a God onto themselves. Shooting themselves trying to smoke a 8 inch pipe full of it buried in their laws. They can stuff it. Unfortunately they need everything from the rest of the USA while supplying basically all the things to eat.
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    2000 pounds.
    On a serious note, that is the rating for the suspension. 99% of trucking either of those suspensions are fine.
    Iron-Man Thanks this.
  10. x1Heavy
    34,016
    42,139
    Mar 5, 2016
    Suspension Ratings usually have a cushion of percentage. If like Oscar stated, loading a 38K with 40K freight is not going to hurt it none. Just don't make a habit of it. Ive had 135,000 on a 40 foot box with a 60's offset Mack tractor with it's engineering essentially overloaded beyond reason. One of the symptoms was the wheels themselves with tires swaying side to side as the bearings floated on the flexing axles. That caused me to rethink leaving the dock. I was very stupid that day.
    If you ever have problems with your drives, you want to look inside from the top of the dual tires at the inside of your drum and see if you see bearing parts falling out. That will be your only warning before your next turn pulls the whole axle and dual wheel assembly out of your gearbox and axle housing into the opposing traffic as happened to me once.
  11. motor275
    motor275 Bobtail Member
    13
    11
    Jul 29, 2016
    A Volvo with a Detroit sounds like a sweet set up .
