Help.. Black smoke
Discussion in 'Trucks [ Eighteen Wheelers ]' started by The blue guy, Jan 13, 2015.
  1. The blue guy
    The blue guy Light Load Member
    83
    4
    Jan 4, 2015
    My truck is on the road now, and anytime take foot off gas pedal, alot of black smoke comes out of the exhaust, anytime floor it, black smokes come out. But if it stays constant speed no smoke.
    No check engine light or anything us on. The truck mechanically is running normal. Any help would be great. Its a detroit DDec 5 12.7L on a freightliner century.
    My driver checked around the turbo and no oil anywhere, it was dry.
  3. The blue guy
    83
    4
    Jan 4, 2015
    Now the check engine light comes on and off and when it comes kn. its misfiring. :(
  4. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Might want to check this out blue guy..
    http://ww2.justanswer.com/uploads/gowest/2011-08-23_045515_ddec_v_erronious.pdf
    Beings I seen in a earlier post from you about another code maybe you have multiple things going because of this service bulletin? Might be worth checking it out. Hope it helps you.
    barroll Thanks this.
  5. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    910
    Mar 16, 2013
    I don't know about the new ones but we used to call it "Pourin on the coals" in the old mechanicals every time you grabbed one it'd send a nice little puff out the stacks, and any of us who had them turned up got a steady stream till it blew it all out then the next gear we'd get more smoke.
  6. gudethangs
    gudethangs Bobtail Member
    23
    Dec 14, 2014
    Check the clamps on the EGR hose. One could be broken. I have a Det. 60. Did the same thing.
  7. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Did you look up the error code?
  8. The blue guy
    83
    4
    Jan 4, 2015
    I got a new error code reads :
    Eng aux. In/out #1
    calib 128 155 13
    Any ideas? Thanks
  9. Powder Joints
    7,508
    7,417
    Sep 25, 2007
    Rosamond, SoCal
    Too much fuel, We used to like that look, shimimming fule pumps, changing out injectors.
    May just need to have the ecu reset.
  10. The blue guy
    83
    4
    Jan 4, 2015
    Got an update from the shop:
    they said its giving codes for the egr valve and I have to get a new one. $856 dollars.
    I put the lucas injector cleaner and it stopped giving the smoke. But now the truck keeps misfiring like crazy.
    could the egr do this, or is there a problem with the injectors?
    thanks for all the help
  11. The blue guy
    83
    4
    Jan 4, 2015
    Update: Put a New Egr valve and now running great.
    Except it sounds like my turbo is whistling a lot louder. any ideas?
    Thanks everyone
