HELP Can't get ground in the cab
Discussion in 'Kenworth Forum' started by We Hire, Jun 3, 2013.
  1. We Hire
    We Hire Bobtail Member
    12
    Jul 19, 2012
    Any advice on trying to get ground in the Cab of a 1997 Kenworth T2000?
  3. dutchieinquebec
    dutchieinquebec Road Train Member
    1,282
    4,863
    Sep 30, 2012
    Granby.QC
    buy a bag at a home depot ?????
    black_dog106 Thanks this.
  4. dutchieinquebec
    1,282
    4,863
    Sep 30, 2012
    Granby.QC
    all the metal part are ground dude.
    the frame of the dash
  5. pawpaw1
    pawpaw1 Medium Load Member
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    Well , you might try running a ground wire , from some metal part of the cab, like where something's bolted on under the hood, directly to the negative battery post.
  6. Kit76
    Kit76 Bobtail Member
    49
    41
    Jul 10, 2012
    West Lafayette, IN
    Try the one for the CB. Our repair guy working on the fuse box had the same problem and ended up connecting his tester to the CB ground. If you're trying to ground an inverter, good luck. Haven't found a way to do that and have to use a 12-volt plugin style.
  7. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    We Hire:
    Repeating what pawpaw said. I run ground straps in several places on my truck. Electrics get very whacky if they cant get to ground. A good ground is as important as the hot wire feeding. Running a couple of ground straps costs pennies but the benifits can be very important.
