Help catalytic converters
Discussion in 'Trucks [ Eighteen Wheelers ]' started by loudhornsrule, Feb 5, 2009.
  1. loudhornsrule
    loudhornsrule Light Load Member
    74
    40
    Jan 29, 2009
    north texas
    Any good way to gut the catalytic convertors on an o7 pete w/ cat engine. Want to gut them without removing. Thanks
  3. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    ive heard some will pound a piece of 4-4.5 in pipe ( like well casing pipe)thru muffs. i would think this would not produce good flow. never done this myself. why not use straight thru muff ? they are direct replacement to what you have now. also cheap and quiet. i run them on my 06 MXS. very happy with them.
  4. 05379
    05379 Light Load Member
    115
    Nov 15, 2008
    montague ma
    plus i heard they are big bucks if you had to replace the cat's for some reason.i put straight threws on my 05 mxs i am very happy too.so is my kitty.
  5. SPIKE 64
    SPIKE 64 Light Load Member
    150
    27
    Feb 26, 2008
    San Antonio tx.
    Put a couple of Dynaflexe's,They are cheap and look like a factory job for around $55. BTW it will be kinda hard to break the cat/converter while on the truck cuz the converter part is on the bottom section of muffler just look for the spot weld's on the side of your muffler.Good luck............
  6. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    IF you have a dpf on the truck you may not be able to swap out the mufflers. The dpf puts out so much heat that they are actually discoloring the exhaust stacks. Also I think it is against the law to replace any of the exhaust with any thing but OEM parts if the truck has a dpf. I have heard that this law covers the whole exhaust and I have also heard the it only covers from the dpf forward. If you can replace the mufflers, I would go with either the dynaflex or diesel injection mufflers. Just don't go to straight pipes. This day and age you need some noise cancelation.
  7. Heavyd
    Heavyd Road Train Member
    7,767
    6,204
    Feb 4, 2009
    You can't remove any of it for the purpose of eliminating it! Have a look at the sensors that go the muffler. You simply can't leave them unplugged or install a blank or empty exhaust piece. The ECM needs to see certain pressures, back pressures and temperatures that only these components produce. If you disconnect these you will start with a Check Engine Light and very quickly have engine derate to the point the truck is undriveable, then a Stop Engine light! These are emission required parts that are electroncially tied to the engine. The catalytic converter is used to increase the temp of the exhaust gases to burn off the trapped unburnt fuel in the DPF.
  8. PaulE
    413
    145
    Jan 15, 2009
    Verona Wi
    07 truck is likely 06 engine. poster did not indicate DPF.
    FWIW, google DPF bypass kit. co in ST George UT sells them
  9. loudhornsrule
    74
    40
    Jan 29, 2009
    north texas
    Not worried about the law. No wires on exhaust. thanks
  10. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    From what I saw of these mufflers on display at Louisville a few years ago. I wouldn't do anything to them, but remove them. The inside is not made like a normal muffler with a set of baffles inside. You won't be able to get good flow by trying to make them a straight through muffler. Buy a set of Donaldsons off road mufflers and you will more than pay for them with the fuel mileage increase
  11. loudhornsrule
    74
    40
    Jan 29, 2009
    north texas
    Alot of good replies, thanks alot
