Help!!! Chasing whining sound Cat C15 Acert
Discussion in 'Ask An Owner Operator' started by W903B, May 6, 2020.
  1. W903B
    W903B Light Load Member
    80
    26
    Jun 5, 2016
    Hello all, I m chasing a whining sound which I can't find
    Symptoms, whining sound ( like sound from speakers) is coming from right side or front of Cat C15 Acert MXS sound can clearly heard after quick throttle like sound is followed by rpm , less on idle more sound on rpm.
    What I did.... Cat house and local mechanic pointed turbo and I changed it mounted on exhaust manifold side 10R2407 sound came back
    Took both belts replaced idler no change.
    No exhaust leak but changed Flex pipe next to turbo , no change.
    No codes no power issues , rebuilt in October 2019
    What you guys advice Thanks in advance
    Deere hunter Thanks this.
  3. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Spray everything with windex and have someone watch for bubbles when u rev in up. Boost leaks are a very annoying variety of sounds. The throttle delay coincides with a rise in boost and thus leakage.
    W903B and Deere hunter Thank this.
  4. Ridgeline
    22,605
    120,018
    Just a thought ...
    If you bring the revs up is the sound delayed ramping up with you coming off the throttle being delayed going down?
    Turbos spool up and down, so it is a way to rule out turbos and boast components.
  5. Deere hunter
    2,118
    9,986
    Aug 5, 2017
    Shallowater Texas
    Turbo’s whine so do drivers, wives ,children and mostly politicians. If you figure out how to stop the whining or where it’s coming from please let us know!!
    sarcasm :argue:
    but I’m betting it’s still your turbo. I’ve changed turbos many times still whining .
    W903B and FoolsErrand Thank this.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    Check all the bellows for cracks, sometimes they can be very hard to see.
    W903B Thanks this.
  7. FoolsErrand
    2,877
    12,169
    Sep 15, 2017
    When i spray my wife with windex she bubbles profusely.
  8. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,896
    Sep 20, 2015
    Southern Ontario
  9. W903B
    80
    26
    Jun 5, 2016
    Thank-you all , yes the noise is delayed like echo from revs/acceleration, so 1 turbo is changed I need to change the second one which is way more expensive 1888
  10. W903B
    80
    26
    Jun 5, 2016
    I feel when truck is cold there is more noise like oooowww crying , can it be internal engine components , coz it's recently rebuilt and I can't afford another head
  11. FoolsErrand
    2,877
    12,169
    Sep 15, 2017
    Driver, stop buying parts. Buy a good mechanic and only replace precisely what has failed after its been verified as the issue. It may be a $30 silicone boot or band clamp that youre throwing turbos at.
