Just a suggestion ...
Now don't do this for a long time.
Take your fan belt off.
The run your engine, this will eliminate fan clutch, water pump and alternator.
You can't run the engine for more than a minute or two before the heat builds up.
Help!!! Chasing whining sound Cat C15 Acert
Discussion in 'Ask An Owner Operator' started by W903B, May 6, 2020.
Page 3 of 3
Water pump is gear driven.650cat425 and Deere hunter Thank this.
Didn't remember if it was or not but the fan and alternator should be belt driven.
Yes, it is dying but I removed both belts and checked everything , sound is still there , it does not go away. As alternator us dying I m keeping new one in can for emergency.
Hello Oscar , I doubt water pump or from crank damper area, is there is way to check,
Turbos are fine , no air leak , no exhaust leaks , no pulley or idler pulley, no fan hub , opened valve cover yesterday looks fine, I do hear growling noise standing left of damper
I have minor pin hole leak near coolant filler cap, saw few coolant drops on steel line goes to after cooler. -
I live in Winnipeg, Manitoba, Canada and runs to Toronto,Ontario area.
Winnipeg, Canada
Page 3 of 3
