Help cleaning engine for INFRAME REBUILD
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AUSSIE DAVE, Mar 26, 2010.
  1. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Hi all, I have just degreased the entire outside of my M11 ready to start pulling it down before starting the inframe rebuild. Just after advice of the best way to clean the area inside the block/head were water/coolant travells. Is there a clearner/chemical that i can use to clean the water galleries and engine block, ? P.s also is there a chemical/cleaner to clean out the radiator. ENGINE and RADIATOR NOT JOINED AND ENGINE NOT RUNNING, so an off the self cleaner is of no use because I can not run the engine.
    HOPE THIS MAKES SENSE. regards Dave :banghead:
  3. ironeagle2006
    ironeagle2006 Road Train Member
    If cap the end of the raidiator off then fill it with water and Baking Soda that is what I used to OH farm engines then let it soak for a day then uncap it. For the blockuse a Pressure washer after you have the liners out of it and blast them as clean as you can get it.
    AUSSIE DAVE Thanks this.
  4. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Thanks for the info:biggrin_255:
  5. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    ironeagle2006, how much baking soda should i put into 1 gallon / 4.5 liters of water
  6. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    bump:biggrin_25510::biggrin_25510::biggrin_25510::biggrin_25525::biggrin_25525::biggrin_25525::biggrin_2551::biggrin_2551::biggrin_2551:QUOTE=AUSSIE DAVE;1275839]ironeagle2006, how much baking soda should i put into 1 gallon / 4.5 liters of water
    [/QUOTE]
  7. ironeagle2006
    Sorry was Banned for a week called royally falmed someone in the Politics section. Think Aussie Football style then kick their gonads thru the goalposts. I would use about 2 cups of Baking soda per gallon of water.
  8. Donk
    Donk Have a Cup Of Concrete
    1,643
    9,232
    Apr 27, 2008
    Dave, 1 us gal is around 3.8 litres
  9. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Ok thanks, keep forgetting that. got a habit of thinking it is 4.5
  10. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Greatly appreciate that, thanks.
  11. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Just an update FYI - Started pulling down the M11 on Friday, so far the Crankshaft, and conrods are in good order, and the head looks like it will be crack free as well, (yippy) it appears that the head gasket let go at number 5 cylinder when the previous owners driver/employee blew it up. P.s Jakes, rocker gear, etc all look good also. so I might get the inframe done for around $3K - $5K.
