Help!! Company needs safety rating upgrade 385.17 after given "UNSATISFACTORY" rating
Discussion in 'Trucking Industry Regulations' started by skim, Mar 16, 2013.
  1. skim
    skim Bobtail Member
    39
    6
    Nov 30, 2010
    Los Angeles, CA
    Hello everyone! I am new to this forum and seeking some help / advice from any companies/ individuals that have gone through the process of upgrading safety rating from "unsatisfactory" to "satisfactory" status. We are under the section 385.17 process. Our company started its operations approximately 2 years ago, upon starting we did not have much experience in the HOS department and how as a company, to stay on top of all of the safety compliance. In the first year we racked up a large number of violations at the scales and out of services for both vehicle maintenance and driver fatigue hours. The second year of operations was better, less violations and out of services - of course we still had them occur but not to the extent of when we first opened and weren't so careful about it. We run a tough lane - the California Interstate 5 Corridor which consists of CA - OR - WA.
    Because the number of violations we had an audit in January of this year. The result of the audit gave us an "unsatisfactory" rating and gave us 60 days to submit how we are cleaning things up and how we will prevent our company from having issues moving forward. We are in contact with the Enforcement Motor Specialist at the FMCSA. They are requesting quite a bit of detailed information from us that we are currently putting together. Hopefully we will be able to put together the right information and get it over to them as soon as possible as we have already gotten a notice from them to cease all operations due to our unsatisfactory rating at the end of the month...
    Has anyone here been through this type of situation that could provide some insight to this? Our main issues that we need to tackle are the hours of service and drug / alcohol testing policy.
    How long does it take for them to change the safety from "unsatisfactory" to "satisfactory" once received (if they approve)?
    Can we request an extension to the order to cease all operations?
    I would hope to get enough information here if I could to try and put together the right information so we do not get shut down and can upgrade our rating.
    If anyone could help me out I would really appreciate it as this is very stressful and coming at a time when we are getting our act together in this department, however the problems/ violations that occurred when we did not have much experience (we still are learning, but a little better) is coming back to haunt us and threatening to shut down our operations.
    If you could reply here OR better yet PM me so we could discuss in detail that would be great.
    Thanks again for taking the time to read this and have a great day!
  3. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I'm curious, as we haven't yet been through our new entrant audit. Did the auditors point out what needed to be fixed during your new entrant audit? And did you fix these things? Is your Unsatisfactory rating a result of not fixing the items that were identified in your new entrant audit?
  4. skim
    skim Bobtail Member
    39
    6
    Nov 30, 2010
    Los Angeles, CA
    Thanks for the reply.. we passed our entry audit with flying colors. The person who did that audit did not go into detail checking our log books, it was more of a new company audit where they would look to make sure we had all the correct files in order and up to date. With the second audit the agent came to our office and looked meticulously at EVERY file we had including driver records, drug and alcohol, and log books where they checked hour by hour, bols, fuel receipts... The reason for this second audit was because of our high safety rating I believe. So to answer your question during the new entry audit they did not point out any flaws and the unsatisfactory rating was due to the 2nd audit when the auditor came and dug through our files to identify the issues.
    windsmith Thanks this.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    CSA2010 is working as it was designed to do .....
    Now every time you go through the scale you have a very high chance they are going to haul you in, and rightly so.
    One way out of the hole you are in is to show perfect inspections to hopefully appease them not to put you off the road.
  6. wichris
    wichris Road Train Member
    4,276
    8,602
    Jan 17, 2011
    After six months you can request another compliance review. If everything is fine with that one they will move you to a conditional or satisfactory. There is no "upgrade" to a satisfactory by filling out a course of action.
    Must have been fairly bad if you got a order to cease operations.
  7. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    From what I have read, they are cutting back on the extensions, as too many got the extension and continued in their old ways. As to HOS, the quickest remedy is to install EOBRs, in your trucks, get off of paper logs, then penalize the drivers that continue to screw up. For drug and alcohol, join a good drug testing consortium and apply a no tolerance policy. This might get you back in good graces.
  8. gokiddogo
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    It's gotta be pretty bad.
    Don't they usually order EOBRs as the last step before they cease your operations?
    Isn't this what happened to that reefer company, JBS, I think they are called?
  9. Autocar
    3,167
    2,358
    Apr 28, 2012
    They can no longer order a company to go to EOBRs. However, if the company shows that they will install them, the DOT will look favorably on that plan.
    gokiddogo Thanks this.
  10. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    When did that come about?
  11. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    I guess the cheapest and fastest way to e log your drivers is via cell phone with the elog capabilities. Cheap and easy you can do that as a start. How many trucks u runnin?
