Help converting Dayton/spoke hub to Unimount/hub piloted
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AFservices, Mar 16, 2014.
  1. AFservices
    AFservices Bobtail Member
    I have a 1995 L8000 with a 16k front and 23k rear, and it currently has Dayton spoke wheels. its time to do king pins and brakes and id like to change it over to Hub piloted in the process. i have google searched my hub number and bearing numbers but i havent found any solid information on matching unimount hubs. I know people say to call junk yards, However my local wreckers are absolutely no help. I have the following information on my front hub:
    Front hub casting number: FX196
    Inner cup: 552A
    Inner cone: 555S
    Outer cup: 6420
    Outer cone: 6461A
    But they still can't tell me what hub I need to go hub piloted. Looking online it looks like a #2530 Webb hub should work. But I am not 100%. I have no way to confirm. I'm just taking a guess. If anyone happens to have any experience with this and can tell me what i need to look for (and where to get it cheaply would be a plus) I'd greatly appreciate it.
    Thank you,
    Andrew
  3. Yogibear
    Yogibear Light Load Member
    64
    24
    Nov 4, 2008
    Bristol, Florida
  4. AFservices
    Thanks. I found that site this morning. I hadn't been able to find any concrete information on the FX196 until then.
    That site cleared everything up.
    thank you for replying, that should helpfully help anyone else looking.
    when I order my parts ill reply back if it all works out.
  5. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    CALL the company that made your hubs and with the part number they will tell you all the part numbers you need to do the conversion. It is that simple, I have done it before.
