HELP!! Engine 2 SPN 102 FMI 18 on a DD15
Discussion in 'Freightliner Forum' started by SouthernKomfort, Jun 18, 2020.
  1. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    Run a bottle of Diesel Kleen and after that a bottle of Lucas DPF deep clean they will help clean out the injectors and DPF. If you haven't fixed the air charge problem then it's still there the truck is not running properly which will cause more regen. If you idle a lot you should have bought a truck with APU, or install one.
  3. Ezerix661
    Ezerix661 Bobtail Member
    Mar 6, 2022
    What turned out to be the problem?
