HELP GUYS
Discussion in 'Ask An Owner Operator' started by thecubantrucker, Aug 11, 2019.
  1. thecubantrucker
    thecubantrucker Light Load Member
    145
    89
    Jun 2, 2019
    so driving down the road heard air leak check and air bags were down found a hose to be messed up replaced it now when I got home my leveling valve was leaking alot from bottom and air bags way high replaced it and now the valve under my 5th wheel is leaking from them bottom and air bags not really inflating I believe it leaking with my valves pushed in or not so stressed ugh
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    What is your air pressure gauge showing?
    I had one mess up one time and build 200 pounds pressure, it will sure tell you where the weak spots in your lines are. lol
    MartinFromBC Thanks this.
  4. p608
    p608 Road Train Member
    2,181
    2,992
    Nov 10, 2016
    How do you build 2oolbs of air pressure when the compressor cuts out at 120?
  5. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    The governor is what cuts the compressor off at 120 or what ever you want to set it at. I keep mine at 130 on one I pull a belly dump on. The compressor will keep building air until the popoff blows and releases it. There has been cases where the governor malfunctioned and the popoff was froze, they will build up until it stripped the bull gears on the front of the engine. There is no real limit to how much pressure the compressor will make.
