HELP HELP PLEASE
Discussion in 'Peterbilt Forum' started by 2000peterbilt, Jan 31, 2017.
  1. 2000peterbilt
    2000peterbilt Bobtail Member
    5
    Hello everyone , I have a 2000 Peterbilt 379 N14 engine my PROBLEM is this the pump and the power steering reservoir get extremely HOT I mean am not trying to exagarate but is SUPER HOT we already put 4 brand new power steering pumps and 2 brand new gear box all hoses are new brand new the power steering reservoir is brand new and nope nothing my problem still there HELP HELP please anybody can help us out please????? Thank you so much
  3. rearview
    rearview Medium Load Member
    325
    9,532
    Nov 8, 2014
    Tenakee Springs
    filter?
    bled correctly?
    2000peterbilt Thanks this.
  4. AModelCat
    160,961
    Is there a power steering cooler? If there is, check that it isn't plugged and that the fins aren't all folded over.
  5. 2000peterbilt
    5
    This year truck does not have a coolant system .
  6. 2000peterbilt
    5
    Brand new filter... Yes bled correctly.
  7. Cat sdp
    Cat sdp . .
    21,065
    73,927
    Apr 8, 2012
    Orion's Belt
    Probably stacked in front of the radiator .... I know they exist because mine has one.
    Joshua Parsons Thanks this.
  8. Cat sdp
    Cat sdp . .
    21,065
    73,927
    Apr 8, 2012
    Orion's Belt
    To the op.... Is this a dump truck with floats on the front?
    AModelCat Thanks this.
  9. AModelCat
    160,961
    Yep up front or it could be oil to coolant.
  10. AModelCat
    160,961
    Power steering is pretty much hydraulics. Heat is generated from working or internal fluid leakage (unlikely since it sounds like everything is new). Also restrictions to fluid flow generate heat.
