Help!!! I am stuck in the ice!!!
Discussion in 'Ask An Owner Operator' started by Gazoo, Jan 29, 2009.
  1. Gazoo
    Gazoo Resident Mental Patient
    626
    56
    Apr 14, 2007
    Bedrock
    I tried backing into a spot at a truck stop in Penn. and I got myself stuck halfway in/out of the spot.
    40,000lbs. in the box, tried the inter-axle, letting out the air bags, rocking back and forth as much as I could, and finally kicking the tires and anything else I felt needed to be killed. Any tips before I call a tow truck in the AM? Buy some rock salt? dirt/sand? what has worked?
  3. sgreer78
    sgreer78 Light Load Member
    251
    62
    Jul 26, 2008
    St Louis, MO
    Wait until it melts.
  4. badcompany
    badcompany Heavy Load Member
    738
    830
    Sep 26, 2008
    cullman,alabama
    salt sometimes works if its not too cold....
    or find a flatbedder to give ya a yank
    Brown Stone Thanks this.
  5. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    chains if ya got em?
  6. badcompany
    738
    830
    Sep 26, 2008
    cullman,alabama
    good idea but if he cant move far enuff to get them on wont do any good
  7. 25(2)+2
    18,749
    45,403
    Sep 18, 2006
    the road less travelled
    Don't dump the air, that makes it worse. Salt will help, or salt and sand mixed, or even just sand or dirt if you can find some of that.You need to get it under the tires and embedded into the ice.
  8. bobbyt
    bobbyt Medium Load Member
    623
    108
    Jan 29, 2009
    Edmonton ab.
    chains will work if done right. put chains on as tight as you can and then try rocking the truck back and forth...gently.. until they are under the tire and then tighten them up some more. i know it's alot of work but cheaper than a wrecker. see if someone will pull you forward a bit just to get you out of the rut.
  9. Dingokid
    Dingokid Bobtail Member
    42
    17
    Jan 28, 2009
    Perth Western Australia
    If you got deep reduction use it with the interlocks, put a smidge on the cruise and see if it will walk itself out, always got me out of slick wet clay.
  10. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    kitty litter, coffee grounds, or chains
    GAPrincess Thanks this.
  11. Brickhauler
    Brickhauler Medium Load Member
    411
    142
    Oct 1, 2008
    Elizabeth CO
    Shingles work pretty good, you can put them down under the tires and get a bite to get moving.
