help lifting big trailer tires techniques
Discussion in 'Ask An Owner Operator' started by Shotgun94, Dec 11, 2019.
  1. Shotgun94
    Shotgun94 Medium Load Member
    460
    317
    Sep 24, 2017
    Georgia
    I need some suggestions. I'm not super strong or buff but I'm changing brakes on a trailer and today exhausted myself not being able to lift the wheel onto the studs. I got the inner one on but the outer is tough.
    I tried prying and stuff but still. I don't have the tire lifting jack. Anyone have any tips. I'm working outside on dirt and plywood.
    Dino soar and D.Tibbitt Thank this.
  3. Tug Toy
    Tug Toy Road Train Member
    7,064
    73,906
    Jul 4, 2015
    Corn field
    Get the hub and tire as close as you can with the jack. Then I use a tire spoon under the tire to lift and rotate the rest of the way.
    But mostly it’s just hard work.
    PE_T, Rounded_nut, Opendeckin and 6 others Thank this.
  4. D.Tibbitt
    156,929
    Take a pry bar and get it under the center of the tire underneath it . One hand on top of tire to guide it onto the studs and use pry bar as leverage to lift it onto the studs. Make sure ur not jacked up to high. U want the height as close to the ground as possible
    PE_T, Rounded_nut, Shawn2130 and 5 others Thank this.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Grab a looong prybar from harbor freight. Use that with a 2x4 and slap wheels on all day.
  6. Shotgun94
    460
    317
    Sep 24, 2017
    Georgia
    maybe my flatbed load bar will help as a tire iron.
    PE_T, Tug Toy, x1Heavy and 1 other person Thank this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Yes like Tibbitt says. Pretend to jack the entire tire into the air. But leave extremely little to nothing between bottom of tire and cement slab. If you can rotate it with one or both hands with tiny amount of scraping from below you have managed to jack a truck wheel and tire combination as low as possible. (He he.. funny yes but deadly serious here)
    Everything else is wrestling with prybars. Big ones 6 foot two inches with a foot blade on one end that has a square cut end. You pound it like a pogo stick to bust ice off your slab. Before you bust slab loose. (GTFO the way when it does...) wriggle this wriggle that wriggle some more. Shake and shimmy and haul. (DO NOT LET GO.... and DO have someone with you at all times. If you are doing this alone, it's not good. **THUMP wait a minute and you meet God potentially.)
    Shotgun94 and D.Tibbitt Thank this.
  8. x1Heavy
    34,016
    42,143
    Mar 5, 2016
    You can loop a ractchet strap from above. click your way up tires and wheel and all.
    Farmerbob1, Shotgun94 and D.Tibbitt Thank this.
  9. D.Tibbitt
    156,929
    That is actually a great idea
    Farmerbob1, Shotgun94 and x1Heavy Thank this.
  10. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Shame that it won't work on drive tires...
  11. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Only a flatbed will have a side rail to hook winch on to, then you can lift wheels up and get them sitting on hub and let them off?
    x1Heavy Thanks this.
