Help me spec out a new trailer
Discussion in 'Flatbed Trucking Forum' started by allan5oh, May 17, 2014.
  1. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Truck : 2002 KW T800, ~20,000 lbs full of fuel and gear
    Running area : Western Canada, Midwestern US, Southeastern US primarily. NO California, truck is not legal anyways.
    Needs:
    - 53 foot trailer for adding LTL to full loads, this is my gravy
    - Sliding axles is great, 10 foot spread for the US, closed tandem for Canada, not a requirement but a huge plus doing what I do
    - Lightweight is also another huge plus, I'm currently about 30,800 lbs
    - For years now we've been getting 50X more flatbed only loads than stepdeck only loads, so I'm leaning in that direction
    I will be keeping my 06 East step and renting it to my dad, so flexibility isn't an issue if I buy a flatbed. I'm primarily looking at the Fontaine Revolution and Alutrec Capacity. Here's the specs I'm looking at:
    53 feet
    tandem
    Centrifuse drums with dust shields
    1 toolbox (Revolution includes 4 turtles and 4 wheel chocks)
    Revolution is either superior slide (dual independent out in Q4) or rear slide only(which is on my spec sheet), no front slide, this is straight from fontaine they will *NOT* do it
    Capacity can be anything, but their independent slider system is out now and is a reasonable weight, that's what I specced
    UBL lift kit
    Michelin X-line Energy T 11r22.5's on aluminum wheels (80 RR, no brainer here)
    Parrallel spindles
    Oil hubs axle vents but no inflation system (might add one anyways)
    22 sliding 3 bar winches, revolution adds 22 rope hooks which double as flat hook retainers
    Still hammering out the details, but these quotes are close enough:
    Revolution comes out at 10,428 lbs and ~47k USD
    Capacity comes out at 8,600 lbs and $56,800 CDN
    Some details:
    Revolution will *NOT* do a front slide, if one axle slides I want it to be the front. It would suck being stuck with a 38 foot wheelbase in canada with ~11 feet of overhang. That's just brutal for loading.
    Lift axle details, the Capacity is specced with a lighter suspension (AANT) that Hendrickson recommends only being lifted in an unloaded condition, the Revolution has the heavier axles (AANL) which allows lifting the axle in loaded or unloaded condition. See here for info : http://www.hendrickson-intl.com/Trailer/On-Highway/UBL-Under-Beam-Lift
    I'm told for a flatbed it is about 325# total. So that narrows the difference between the two trailers. Oddly enough a step deck can add a UBL kit without changing suspension. I'm wondering if I can get away with the AANT and just raise the suspension a bit, also keeping the tandem completely closed would help.
    Oil vs. Grease hubs. Oil comes with a 1 or 3 year warranty, grease comes with up to 7 year warranty but 5 year standard. I do not like grease hubs, especially when it gets to -40 up here. You also cannot check the condition of the bearings easily. This is a no brainer for me. I have no issue doing wheel seals myself, I can get the trailer into my shop easily.
    Parrallel spindle, this makes both bearings equal size, and allows more oil inside the hub.
    Axle vent, I've had vents plug on the hub cap blowing the wheel seal, axle vents will not plug.
    Fontaine claims 3% MPG improvement, Alutrec claims 6-9% improvement. You can see why, but I think Alutrec is being a little generous here. But it is a slick trailer.
    The deck height of the Capacity is VERY low. The goose is 3.5" thick, my 5th wheel is 47.5" high so that gives me a 51" trailer height at the front. Most Flats are around 59-60". I'd actually be half way to a step deck.
  3. Cummins_444
    Cummins_444 Medium Load Member
    605
    1,014
    Apr 28, 2008
    Northwest, IN
    Sliding winch rails both sides!!
    MJ1657 Thanks this.
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Most definitely.
  5. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    They both have 22 sliding 3-bar winches and alternate down the sides.
  6. mtoo
    mtoo Road Train Member
    1,935
    4,500
    Jan 15, 2011
    Retired on bended knee
    nailing strips, I know the Revolution, you can only get strips on the outside rails. I like one down the center also. Can you get any nail strips with the Capacity. I like the deck height of the Capacity, the Revolution is very high trailer in the center.
  7. rank
    rank Road Train Member
    9,918
    113,504
    Feb 11, 2010
    Not sure about western Canada but in ON you're allowed to run up to 10' wide after dark on a 4 lane so long as you have wide load lights....so they might come in handy for you.
    ABS on one axle only if they let you. One less to fix later.
  8. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    You're right about the recolution, and I feel it's probably the same with the capacity. I will ask.
    Western Canada is the same as is minnesota.
  9. fortycalglock
    fortycalglock Road Train Member
    6,153
    6,583
    Jun 25, 2011
    Tourist Town, FL
    I've thought about the Alutrec and I got a quote on a Damsen, after I got past the French barrier. I was thinking of doing a low 53' flat hooked to a Low Max Western Star to try and capture some SDE and DDE freight, as well as haul High Cube containers. I gave up on that though as I feel I would always have to explain the trailer to every new agent I call. The price on the Damsen was shocking, 67,000 plus FET, but that included can locks for $5500. The triaxle was $9,000 more. Crazy prices when I can go out and buy a MAC for under $40k. Let us know what you decide.
    Foxcover Thanks this.
  10. rank
    9,918
    113,504
    Feb 11, 2010
    OK I'll bite what is a low flat?
  11. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Low profile. Most flats are around 58-60". East offers one at 54" and alutrec has one at 52" deck height. This allows you to load 9'2" which is half way to a step deck. If you get a "low" truck and go with a shorter ride height on the trailer you can go even lower.
    Does anyone know the 5th wheel height on a western star lowmax? My t800 is 47.5"
